Question about HP Office Equipment & Supplies
In printing there are un wanted black batches and lines.i have changed drum two times. so i am unable to control it . please help me hp laser 1100 printer
    President:
  • 1,223 Answers
Have u changed the cartridge it self u are buying a new one right no refilled stuff if thats the case drum cartridge and the thirs thing is may be piece of paper is stuck inside which got wet with the ink every time u try to print it gives u lines on print pls try this and tell me or tell me the status of ur cartridge and drum
Posted on Feb 23, 2009
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
Lanier LP020c laser colour printer horizontal lines
as if the cartridge is new.and colour is printing fine.then its not faulty cartridge or faulty printer.and yes you are absolutely right that it needs proper servicing.in the printer there are lens one lens is for colour and one lens is for black.if there is dust on the lens controlling black you will get lines and patches in black prinouts.but yes if the drum is got lines on it.that it will give same lines in the printouts.also you can get the drun serviced first before getting the printer serviced.a local printer repair shop does this drum servicing.also there comes a liquid to clean drum.you can get it from printer parts store.if want to do manually.but the shop will get it checked after serving in there printer.so it will be confirmed that is it drum or faulty /dusty lens in the printer. ----------- this will help.thanks.
Sep 20, 2009 | Lanier UNKNOWN
Lines down the paper HP 4600DN
This means that the problem is with the toner drum. Just try to clean the drum of the toner with cotton. It is green colored rod in the toner. then try to take the print. If still you get the line while printing please either replace the toner or get the drum replaced from a local vendor
Jul 14, 2009 | HP LaserJet 4600dn Color Printer
Hp laser jet1100 prints white lines
Hi ejazmusavi:
Try this.
Toner/developing cylinder 37.7 mm (1.48 inches)
Toner/primary charging roller 37.7 mm (1.48 inches)
Heating element 56.5 mm (2.22 inches)
Transfer roller 45.2 mm (1.78 inches)
Pressure roller 62.8 mm (2.47 inches)
Toner/drum 75.4 mm (2.97 inches)
Feed roller 55.1 mm (2.17 inches)
Hope this helps
May 29, 2009 | HP LaserJet 1100 Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Black Lines
you need to change drum
elvis
Apr 18, 2008 | Brother HL-5240 Laser Printer
Black Streaks
The Black Lines are not due to to toner problem.
The Black lines ate same at the Page Location . If so the Problem may be with Drum Or Charging Unit Or fuser assembly. If the same problem continues Please take out and see the drum do not toch it . (Please Power off the Printer and disconnect all the cables. )
REgards
Rafique
Mar 12, 2008 | Samsung CLP-510 Laser Printer
HP Laser Jet 1100
Ok fine do you want to refill the old one or you want to take the catridge from the printer if you need Manule i can give you the link where you can download the manule the use it
Thank you
Mar 04, 2008 | HP LaserJet 1100 Printer
Seeker5211
Seeker5211
