Question about E-Machines T2642 PC Desktop
3 cables came unplugged 1 is green pwr led 1 is pwr s/w-black ,one is red hdd led i just need to know what order to plug them back in
    President:
  • 2,653 Answers
The order doesn't matter. Just make sure they go back where they came from. I
Posted on Feb 23, 2009
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
What colors are the wires for the pwr sw, smi,rst,hdd led,grn led and where so i plug them in at s7sen 15-a01-013010 rev 3.0a
- the colors of the wires (can differ, depends on the case type):
  • Green(+ is the colored wire)-White(-) --> POWER LED (GREEN light)
  • Red-Black -> POWER SWITCH
  • Red-White -> HDD LED (RED light)
  • Blue-White -> RESET
  • Red-Black (4 pins wide)-> SPEAKER
Sep 03, 2010 | EliteGroup K7SEM Motherboard
E-Machines T2642 PC Desktop from mother board 3 cables came unplugged 1 is green pwr led 1 is pwr s/w-black ,one is red hdd led i just need to know what order to plug them back in
Sorry you are having trouble.
Led's have a + and a - side.
With a magnifying glass you should be able to see where each one goes on the board. Start with pwr s/w. when you have it on the right pins then you can push the button and turn it on. I have done with with a screwdriver and quickly touching two pins at a time until it comes on.
Next the power LED. This one should be on all the time.
Last id hdd LED. This one will only be on when HDD is active and reading or writing.
The connector you are looking for is normally in the right hand corner opposite the power supply and has all the wires from the case going to it.
Apr 05, 2010 | E-Machines T2642 PC Desktop
Unpluged HDD LED PWR S/W and PWR LED for board
it's usually written in fine print beside pins. Failing that get the manual which tells you
Feb 26, 2010 | E-Machines T3958 (827103050974) PC Desktop
I need assistance with the front panel cables (Power, HDD, Reset etc)
On your motherboard power is setup like so:
10 9 8 7 6 (no pin on 6)
1 2 3 4 5
1- HD_LED_P
2- HD_LED_N
3- RST_SW_N
4- RST_SW_P
5- RSVD
6- No pin
7- PWR_SW_N
8- PWR_SW_P
9- FP PWR/SLP
10- FP PWR/SLP
you have 5 connectors from the chassis' front (with cable colors):
-P LED (white)
+P LED (green)
HDD LED (yellow/white)
RESET (white/blue)
POWER (orange/white)
You just insert cables according to these nos. Do this job carefully that's why i am giving you full details about cable and its colors.
Regards
Ashly
Feb 24, 2010 | Computers & Internet
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
HI! I was cleaning the inside of my e-machine W3502 and I putted off the 3 cords labeled Power LED green in color,HDD.LED red in color, and the POWER SW. Now i don't know how to put them back on in order....
look on the motherboard where all the cables are plugged in, It should list on the board in small letters what plugs in there. whats written on top goes on the top pins & bottom list should be the bottom pins.
Jan 14, 2009 | E-Machines eMachines Desktop PC
E-Machines T2642 PC Desktop Logo
64 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
