Question about Epson Stylus Color 800 InkJet Printer
Printer is not printing black ink, i have replaced the cartridge, checked that the PC is not tellin the printer to print in negative. I replaced the black ink cartridge, ran the head cleaning and alignment utilities and still the black refuses to print even when printing a page that uses color. The color portion of the page prints ok.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Basically, it would appear that the printhead for the black is fully clogged or faulty. Initially, pls try to:
  • download, install and run Epson SSC Service Utility;
  • proceed with deep cleaning;
  • reset all counters to zero;
  • unplug everything from the printer for an extended period of time;
  • try again.
Pls post back results/updates. Good luck and thank you for using FixYa.
Posted on Feb 23, 2009
  • 495 Answers
Just try with test page of printer and also reinstall the driver and see.
    President:
  • 1,179 Answers
When you print a test page does the black print? If it does not then most likely it is a clogged nozzle. This would need to be either cleaned or replaced by Epson. The service charge may be more than buying a new printer so you would want an estimate first. Hope this helps & good luck.
  • 6,487 Answers
Do again a dep cleaning because sometimes it requires to repeat the deep cleaning to make everything work...
  • Epson Master
  • 13,433 Answers
Print a test page from the printer and see if black comes out, if it doens't come out, clean the contacts, if that doesn't help the printer head might need to be replaced, in some cases it may cost more than a new printer.
    Brigadier General:
  • 3,614 Answers
do a print head cleaning maintenance, this will clean the dirt on the print head
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Black ink cartridge
Are you using original Cartridge or a compatible one? One possibility is you didn't remove the sticker on the top which covers the air hole., please run a cleaning cycle from your pc before printing and take a nozzle check print.
May 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
PRINTING ON BLACK PAPER
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper. You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does. Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper. (Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.) This will use a LOT of ink, but it may be the only way you can accomplish your goal. Hope this helps...
Aug 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus Color 800 InkJet Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
