Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Bought a reddy heater 155,000 kerosene.It wont draw feul.Hoses are clear (translucent) and also are not plugged. I can blow thru both & hear air come out the oriface. Am try to find out if previous owner may have switched placement of the air and feul lines?? anybody?
  • 181 Answers
The fuel line goes to the back of nozzle and the air line goes to the front.the air line and fuel line are not clear on that unit.sounds like some one changed them.also the fuel filter goes in the unit backwards from what the arrow shows.check your air pressure.you need to put a gauge on it so it is correct.
Posted on Feb 24, 2009
When plugging in my reddy heater 110 it blows air & no heat and then goes off.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 12, 2011 | Reddy Kerosene Heater with Thermostat:...
Reddy heater blows the fuse in the control panel,
Check out on the nameplate on Reddy Heater how many amps it draws and what size circuit is needed.
It could be that you have an undersized wire and outlet where heater plugs into
Jun 18, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Kerosene heater - will ignite and burn with the cover off. when cover is replaced the heater quits. it is a reddy pro 155 (155,000 btu)
It shoulds like it could be an air flow problem. I suggest you get on the manufactures website at www.desatech.com . They offer service manuals for these heaters. I hope this helps you!
Jan 25, 2010 | Reddy Heating & Cooling
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Mar 09, 2009 | Reddy Heater 60,000 BTU Kerosene...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
251 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
