Question about Microsoft Windows Server Standard 2003 for PC
How to configure domain - Microsoft Windows Server Standard 2003 for PC
    Sniper:
  • 93 Answers
U may visit this site get the information about the configure domain http://technet.microsoft.com/en-us/library/cc736345(WS.10).aspx
And then before configure u must register the domain name .For this u may use this site http://www.tucktail.com/
Posted on Jun 06, 2009
    Sergeant:
  • 268 Answers
You need to install and run IIS or Apache...they are both web server programs. It doesn't really matter which you use, more of a user preference.
In my case I like to use IIS with Server 2003. Below is a link that is a full guide for setting up your server to host a website. it is step by step and includes pictures along the way. It should have you running in no time!
Step By Step Guide
Posted on Feb 24, 2009
WLC configured with "A" domain
-A you can use USA and Canada
-N you can use at Mexico
Sep 10, 2011 | Cisco Aironet 1142 (AIR-LAP1142N-A-K9)...
We have a KM bizhub 250, and we upgraded our server to a SBS 2008 Server. Now our scanning is not working. What could be the problem?
If this server is also a domain controler that is usually caused by the following setting:
Microsoft Network Server: Digitally Sign Communications (Always), The default setting for domain controllers is enabled, for others is not configured or disabled. This usually causes problems when acessing the share from devices are not cable of Digitally Sign Communications, like some multifunctionals/scanners or linux machines. This does not happen on all machines since some are capable of Digitally Sign Communications. Usually older machines have this issue.
So, try to disable this setting on the server, on the Domain controller security policy and Default Domain Policy.
Administrative Tools
Local Policies
Security options
Microsoft Network Server: Digitally signed communication (always) -> should be changed to DISABLE
Execute Gpupdate /force or reboot the server to apply the policy change
You will not be able to change this setting trough gpedit , local computer policy since it is overrided by the Domain security policy.
On server 2008 one way to get there is the following:
Server Manager
Features
Group Policy Manager
Forest: ...
Computer configuration
Policies
Windows Settings
Security Settings
Local Policies
Security Options
- Define This Policy
- Disabled
Execute Gpupdate /force or reboot to apply policy
Trough gpedit you will be able to see the option but not change it, so I suggest that after the change you cannot scan to the folder check trough gpedit if it is disabled.
If it is not disabled, disable it at the top of the hierarchy. Something may be overriding the setting.
If it still does not work try the following, togheter with the previous setting
Domain member: Digitally encrypt or sign secure channel data (always) -> disabled
Dont forget to execute Gpupdate /force or reboot to apply policy each time you change something.
Also
are you scanning to the server using \\server_ip_address\shared_folder or \\server_name\shared_folder?
Just wondering about name resolution.
Is the domain field configured in the machine? if not you might have to specify the user for authentication like for example: user@domain.local
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
How do i change the configuration from domain to work group
even if you mistakenly joined a domain you can still log in through your existing id and password.
Once your press CTRL+ALT+DEL, you will see a login window with three fields namely: user id, password and Domain.
In the log in screen use the drop-down menu in front of Domain (which shows your new domain- most likey MSHome) and choose 'this computer'. After this, enter your old/existing user id and password and hit enter.
Please proceed to your system settings and change your domain back to Workgroup. Restart PC.
Sep 30, 2009 | Dell Inspiron 1420 Notebook
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
Dear sir, How can i configure my domain
First and formost, you need following check list before configuration
1) System partition must be formatted as NTFS.
2) Machine must have static IP address.
3) DNS installed
Then run a dcpromo command and configure domain.
Jun 10, 2009 | Microsoft Windows Server Standard 2003 for...
DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
Mar 24, 2009 | Microsoft Computers & Internet
What is domain test??
Domain testing generally includes DNS resolution and configuration of you domain name. It can also include the network performance of the DNS, WEB and other services attached to the domain.
For a more detailed description of domains and DNS see:
http://en.wikipedia.org/wiki/Domain_name_system
For an example of some of the domain testing techniques see:
http://www.testdomain.net/
Mar 02, 2009 | Computers & Internet
Cant acess dlink keeps asking for domain
Setup the Local Domain Name on your router. To do this you may need to logon to the configuration page of your router.
Feb 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
How to configure additional domain controller in win 2003
execute dcpromo to convert a win2003 to a domain controller.
Global catalog is not replicated by default to the new promoted 2003 domain controller.
Feb 17, 2009 | Keystone Microsoft Windows Server 2003...
Microsoft Windows Server Standard 2003 for PC Logo
128 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
