Question about Lenovo R61 T7300 Notebook
I have a gigabyte g945 motherboard when i power on my pc in the morning it is not powering on. i have also changed the cmos battery but still the problem is persisting along with me can anybody help me to give a better solution to solve this kind of problem.
  • 42 Answers
-check the power suply cable
-make sure the on/off button isn't damaged
-check the motherboard for any burn out chips
-make sure the currant is actully running thru all circuits
-check the parts that could die and cause this: processor unit, memory units (not the hdd), cables and connections
Posted on Feb 23, 2009
Continually blinking beep..!!
cmos pin reset then take out battery then wait one min put it back or you will need to recover bios by reflash them to factory setting
Nov 11, 2013 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
GA-K8NS losing Cmos - not the battery
Hi, you can download drivers and software here:
http://www.gigabyte.com/products/product-page.aspx?pid=1783#driver
Try to change the cmos battery.
When the battery run out of power the bios can`t
remember its settings.
Thats probably why you have a cmos error.
The battery is a 2032 watch type.
You can try to remove the battery and measure the voltage
with a voltmeter.
Its should be around 3 volts.
Consider to upgrade the bios when you get it up and running.
You have to make sure its the right mainboard when you flashing
the bios or the mainboard will be destroyed.
Sep 07, 2011 | Gigabyte GA-K8NS Motherboard
Hi... i have gigabyte ga-945gcm-s2c and i dont know where is the jumper to bios clearing CMOS... please help me to fix this problem... thanks before....
You can get the manual here:
http://download.gigabyte.eu/FileList/Manual/motherboard_manual_ga-945gcm-s2l%28s2c%29_e.pdf
But if you look to the right of the CMOS battery, you will see two pins, to reset the cmos, simply cap the pins with a jumper for 10 secs, or touch them with a screwdriver (mains power OFF of course)
Apr 19, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Good morning,my pc have a message like "cmos checksum error" and it don't start,i restarted the bios but i hadn't solve the problem,i have the gigabyte GA81PE775-G MOTHERBOARD
This problem usually occurs when the BIOS information is corrupted and it is caused by a flat BIOS battery.
Replace the BIOS battery with a new one, this battery could be a coin size battery approx. 20mm dia it may be a 3 volt lithium battery type CR2030.
Feb 18, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
I have got a motherbored and it has got a bios password on it and could any one help thanks
You can clear the password by clearing the CMOS. Your manual will show you how to clear the CMOS, If you don't have a manual, go to the gigabyte support website, enter your motherboard model, and you can download the manual
Oct 28, 2009 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
Booting problem
I think the CMOS battery is not connected properly when it is taken off and replaced. Check if the connector on the top is in contact with the battery correctly.
Feb 22, 2009 | Gigabyte Computers & Internet
My pc can't boot
Make sure the battery is facing the correct way.
Dec 25, 2008 | Gigabyte GA-6BX7 Motherboard
Open Questions:
Lenovo R61 T7300 Notebook Logo
48 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
