Question about Sony Car Audio & Video
Head set has power but wont turn on
Has power to back plug was going then stopped turned off ingnition and started again now wont go at all
  • 95 Answers
Have you tried look at the fuse on the back of the radio or if there is one on the battery power wire for your radio. check and make sure your ground is good and that both your battery and accessory wire have 12 volts to it. Check any and all fuses
Posted on Feb 23, 2009
99 Honda wont start now. It started sputtering after I was sitting at stop light. Brought it home now wont start
sounds like your head gasket is leaking and need replacing try turning the engine over with out the plugs in and see if any water comes of the plug holes or do a compression test on each bore to see if they a lower than the over bores hope it help you and you need a torque wrench if you going to do your self and now how to set up the timing marks on the crank and the cam .find them in car book
Jan 20, 2017 | Honda Cars & Trucks
1996 Impala wont turn over
check your spark plug leds sometimes they will come out and that will stop it for starting.
Jun 28, 2012 | 1996 Chevrolet Impala SS
Help car wont start 1997ford tauru I start engine rotates but wont start
have someone turn the ingnition on ( without starting the car ) while you listen by the gas tank. if you dont hear a buzzing sound coming from the tank then the fuel pump needs to be replaced. if you do hear a buzzing then your problem is most likely spark issue. pull a spark plug out of the motor plug it back into its wire and have someone turn the car over and check to see if it sparks. is the check engine light on?
Nov 07, 2011 | 1997 Ford Taurus
I hooked my head unit up and it wont power on yet if i put a cd in it will come on recieve the cd and turn back off also the disp turns it on for a second. what is this?
you need to make sure 3 wire are connet the right way one is constant power,2 ground,3 acc. ingnition also there is 1 more wire you need to connect is the remote blue or blue/light blue.
Dec 27, 2010 | JVC KD-G801 CD Player
Replaced engine. car turns but wont start. power
have you checked that the points in the distributer are set ok and havent closed or burnt,as this is what makes the coil spark the ht lead to the distributer cap to the rotor arm then to the plug leads.
hope this helps
Aug 02, 2009 | Ford Contour Cars & Trucks
1997 buick Lesabre limited all lights come on,wont start
the ingnition switch has a wire broken that wont allow the computer to turn the security system off to let the car start
Jul 19, 2009 | 1997 Buick LeSabre
Got a loncin explorer 90cc quad had trouble with starting it, since i bought it from new. took it back got a new battery and starter fitted at cost was fine for a week or so, but now wont start again, its...
ive bought 1 and had the same problem , change the spark plug for an ngk , and use shell v-power petrol ( or any other high octane fuel ) myn now starts first time every time :) and go's like stink also consider buying a better battery , the standard 1's are **** !
Mar 16, 2009 | Cycling
1992 bucik lesabre limeted wont start
in the dist. the is an ingnition module check that if it is bad it is cheaper to buy new dist. than replacing the module
Jun 30, 2008 | 1992 Buick LeSabre
Car Audio & Video Logo
77 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
