Question about Health & Beauty
Manual wheelchair Hard to PUSH
I HAVE A QUICKIE 2 MANUAL WHEELCHAIR AND IT SEEMS REALLY HARD TO PUSH THESE DAYS LIKE THE TIRES ARE LOW BUT THERE NOT, ANY SUGGESTION WHY IT IS SO HARD TO PUSH
  • kdunbar36 Mar 06, 2009
    Have you clean the axels lately? Maybe there is so much hair and stuff wrapped around the axel part of the wheel... check under the big wheels after pulling them off and see if you find hair wrapped up around them... I used to have a manual wheelchair myself, and that happened to me all of the time. Especially when you have long hair.
    Problem Solver:
  • 16 Answers
Pull off the Big Wheels and see if you have Hair Wrapped around the Axel part of the wheel, sometimes when I used to have a manual wheelchair hair would wrap around it. If not, then it really could be your tires, especially if they have treads on them, you might have warn down the treads making it harder to push, so check both, if your treads are low, then you need new tires, you can either call the person who helped you get the chair, like a wheelchair Specialist or even try your local bike shop, I've gotten tires from them before, they aren't as good as the ones I get from my Wheelchair Specialist - Hudson Home Health Care, but they at the time were better than nothing.
Posted on Mar 06, 2009
I need an owners manual for a quickie asprie power wheelchaie
you can get it from the manufacturer's webste or by just searching google.
Apr 07, 2012 | Quickie Wheelchairs Quickie Aspire Power...
The only time the chair worked [approx. 1/2 hour] was when the repairman cleaned the cables. Since that, the chair charges, turns green for full charge, and only flashes red as soon as the joystick is...
hi.
the link below is for the owners manual for the quickie aspire power wheelchair, free download in pdf format.
http://www.wheelchair-review.co.uk/wheelchair-files/wheelchair-manuals/sunrise-medical-wheelchairs/quickie-aspire-power-wheelchair.pdf
the "cane crutch holder" is an acessory part that you can get, fitted to the back of the seat, to hold a crutch or cane. it does not affect the chair itself at all.
there are two most likely reasons for your problem, neither of which actually involve the arm and controller.
1. if the battery light is flashing 9 times when you try to move, then you need to check the motor locks are engaged properly. see page 27 of the manual for photos and location. these are also known as "freewheel levers" and allow you to disconnect the motors to push the chair manually. if the levers are engaged properly, it is quite possible that the switch, or switch wires have broken and the chair thinks that they are off. these are very cheap and easy to replace and are located where the lever connects inside the chair.
2. if the battery light comes on and stays on, then you may need to have the batteries checked. if the batteries have not been charged for a while then sulphur may have built up on the lead plates inside the battery. this can mean that the batteries will show fully charged, but as soon as you try to draw power, they cannot function due to the sulphur, and instantly show as flat.
any auto shop should be able to perform a battery load test for you to test this. a 100amp load test for about 6 seconds will test the battery performance and let you know if they need replacing. most places will do this test for free but the batteries need to be fully charged first.
hopefully, one of these solutions will work as these are the most common fault for the symptoms you are describing. you should find the manual quite useful as well.
please feel free to ask if you need more information.
hope this helps
Jul 12, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Hi, Hoping someone can help me as I just received my Quickie Aspire Power wheelchair today but they could not supply me with a manual. Can you help me getting one as I've tried looking online. Thank...
Netti Since Sunrise Medical is no longer making these chairs you might have to directly to them Call 1-800-333-4000 and ask for their help Good Luck Hope this helps
Nov 01, 2010 | Invacare Supply Group Invacare Pronto M51...
The wheelchair will only move when the charger is plugged in. Unplug and all lights are normal but no motor actuation. thank you fo4r your help
berry boy Not alot of information but when you say all lights are normal do you mean the battery level lights are all lit up and there are no flashes. Usually when this happens the battery level is too low to make the chair move. When you have the chair plugged up the charger gives enough power to make it move. If you have a digital voltmeter set it 200 vdc then plug the 2 test leads into the 2 outter charger port holes. You should be able to read the battery level and after a full charge should be reading 25-27 volts. Hope this helps
Sep 19, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Trying to obtain a manual for a power chair, Sunrise, Aspire Quickie?
lundsuzy goto: sunrisemedical.com At the home page in the product search box in the upper right type in "Aspire". When that page comes up click on view details then the next page will list owner's manual there your manual will come up and you can print it
Sep 17, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Quickie Wheelchairs Jay 2 J2 Cushion Cover Replacement Wheelchair Quickie Preferably from the UK
I suggest contacting the disabled living foundation (DLF). They are a uk organisation that has information on where you can buy or hire daily living equipment and sources of funding. DLF is a national charity that provides impartial advice, information and training on daily living aids.
website: www.dlf.org.au. phone: 0845 130 9177
May 01, 2010 | Quickie Wheelchairs Jay 2 J2 Cushion Cover...
Battery charger not charging
Try calling Sunrise @(303) 218-4500
   Will the battery charger even come on?
Mar 19, 2009 | Pfizer Quickie Revolution by Sunrise...
Health & Beauty Logo
568 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
