Question about Corel Paint Shop Pro 9
Does anyone know any PSP9 brush sites? all i can find are PSP8 and 7 but and they are too small on my PSP9. please help me.
  • 110 Answers
How do i remove winder stem from rotary skeleton watch
OPEN UP THE BOTTOM AND STICK A SMALL THIN PAINT BRUSH IN AND WIPE IT CLEAN I HAVE DONE IT A FEW TIMES
Nov 18, 2016 | Rotary Watches
Motor Brushes are wedged in..
hi, well with extreme care you can pick away at the brush using a very small screwdriver however you must be careful that you don't damage the commutator on the motor, pick away from the corners in wards keep checking that you haven't hit the motor, extreme care is required here,, please note the brush is made of carbon so will break up...
Regards
Rob
www.gewizrepairs.co.uk
Mar 18, 2014 | Pride Jazzy 1170 Xl Plus JAZZY 1170XLPLUS
Anyone know how to remove the brush holder ring on a bosch 11255 bulldog extreme. the ring does not rotate. so i need to get the ring to rotate and remove the brushes.
if its like the ones I worked on you need to pull the brushes up into the tube and you will nitice a small tab on the bottom of the brush holder, push that in and it should lock the brush up and out of the way, the ring then would have to be turned into a somewhat neutral position to unlock the holding tabs on it. Let me know if you need more assistance. I went to ereplacementparts.com and looked at a parts diagram for this tool.
Apr 13, 2012 | Dewalt Bosch 11255vsr 1" Sds Plus Rotary...
Flexible Shaft Adaptor # 2221-MA00009-00 Carbon Brush # 03AT-000046-00 Brush Spring # 02AH-000088-00 For a Mastercraft Maximum Spin Saw Kit Model # 54-8205-8 Cdn Tire...
By robert_lessa on May 09, 2011
Model # 54-8205-8
Cdn Tire doesn't support their own "house" brand with spare parts.
Does anyone know who was contracted by Cdn Tire to make this unit? That could give me an alternate source for spares. Any help would be much appreciated.
Thanks, Bob
------------------------------------------------------------------ Canadian Tire stopped supporting this product in 2008 and have no parts in inventory ( I am not convinced they ever had a stock of parts) The Spin Saw was manufactured in China by Choon Nang Electric. Your best bet is going to a small engine repair shop and ask if they have universal parts which could fit. Best of luck Claude
May 09, 2011 | Garden
My brushes on my Hoover Steam Vac stopped spinning again! I took the brushes out and they turn fine, but when inserted back into the base, they do not turn, AGAIN! Anyone know what the problem is and...
Tip is slightly, do the brushes spin then? If so, then the brushes are air driven. By the spin indicator at the front of the machine, you'll see a small screen (same type of thing as is in your dryer), scrape it, you'll probably find there's a build-up of fluff. Clean off the fluff, and try again.
Nov 01, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Fault on a Kinzo 115mm Angle Grinder
Hi J,
Hopefully you just wore out the brushes. Replacement kits are available for a few bucks and the fix is pretty easy.
On the darker side, If it overheated enough that it burned the windings (insulation melts, shorts, badness), there isn't much you can do unless it's still under warranty.
You won't know until you get it apart. You'll know which it is at a glance.
Unplug it and dismantle the base of the grip where the cord is attached.
The brushes are small spring loaded graphite blocks that transfer electricity to what looks like a cylinder around the central drive shaft that has a lot of vertical copper strips on it. They are normally housed inside small copper tubes opposite each other.
If those tubes are empty but for the spring, it's brushes.
If the insides are full of ashy residue, it's not the brushes
Best regards and I hope it it's the brushes
Mike
May 27, 2010 | Dewalt DEWD28110 Heavy Duty 4 12"...
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to install programe paint shop pro 9 after loading disk how do you get into psp9 thanks
When you put the PSP9 CD in the drive, it should automatically come up and ask if you want to install. Try removing the CD and then putting it back in the drive.
If that doesn't work, leave CD in drive and go to Start button, Computer and choose the CD drive. Look for Setup.exe and double-click on it. That should start the installation process.
Sep 05, 2009 | Computers & Internet
Cannot installprint workshop 2009
The manual is already installed.
Most software have this installed.
Run the program and click on "Help".
Click on Tutorial or the like after.
I use PSP9 and it gives you step by step instructions on getting started all the way to advanced features.
Aug 11, 2009 | Computers & Internet
Corel Paint Shop Pro 9 Logo
222 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
