When power is turned on light comes on but no functions start. can't open for disc.no elumination of function display
  • bestwinter Feb 23, 2009
    Telefunken TDr218 DVD recorder when powered, no illumination of of display pannel, disc tray won't open and record light come on purple and dosen't turn blue
    Telefunken TDR218 When power is turned on illuminate display pannel is inactive. Disc tray won't open
  • 564 Answers
You can visit Support Website or You can to Service Center.
http://www.telefunkenusa.com/services/
Telefunken USA Authorized Service Centers
Address Telefunken USA
300 Pleasant Valley Rd. (Suite E)
South Windsor, CT 06074-3441
Phone: 860-882-5919
Fax: 860-882-5980
info@telefunkenusa.com
Vertigo Recording Services
10834 Burbank Blvd. Ste V- Rear Warehouse
North Hollywood, CA 91601
Tel: 818-907-5161 or 818-762-1250
Fax:818-762-5095
vertigorecording@aol.com
Hope This Helps!!!  Please Rate my Response!!! Thanks!!!
PREM
Posted on Feb 23, 2009
  • 544 Answers
Thank you for choosing Fixya.com
It seems that your DVD player are experiencing technical problem like malfunctioning the hardware.
Use your technical manual to assist in the troubleshooting process. There should be a section in your tech manual called "Troubleshooting." This is the section you want.
Figure out which part or parts are malfunctioning in your system. Write down the specific parts numbers of the pieces you need to replace. Make sure that your writing is accurate and that the numbers and letters are in the right arrangement as well as capitalized where they need to be.
Check with your local electronics supplier to see if they have the parts you need. If they don’t, they will likely be able to point you in the right direction
Some Tips to Remind:
1. Some DVD players require special tools to work on them. Make sure you're well-equipped before you operate.
2. Get a professional opinion. Make sure that the cost of tools and parts is less than having a professional fix your DVD player.
3. Make sure your DVD player is unplugged before you work on it. Shocking hazards are a very real danger.
4. Double check your warranty to insure that what you're doing will not make your warranty null and void. Often there's a clause in warranties that states that professional maintenance is the only approved work that can be done on your unit.
  • 60 Answers
Disconnect DVD from current.Open the DVD cover. Disconnect the power cables that connects to the mainboard. Check the power supply with a multimeter that if it is supplying recommended power (recommended power consumption might be typed in power supply). If no, replace power supply. If power supply is ok, check the laser carefully if it produces laser beam. Don't directly contact eye with laser beam. Check from a distance. Also check the mainboards biggest chip if it is heating. If laser beams and main chip is heating than your mainboabd might be ok. If does not or one working and another not working, replace mainboard.
Keep informing. (I guess your mainboard has gone)
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem of the Telefunken TDR218 could indicate either:
  • hardware problem;
  • software/firmware glitch.
Initially, try:
  • locate is available a recessed reset button;
  • unplug from the mains for a an extended period of time;
  • press on the POWER/STANDBY button for 5 seconds;
  • temporarily remove the hard disk and determine if it will go through the initialization stage.
Pls post back updates/results. Good luck and thank you for using FixYa.
  • 6,487 Answers
This is already a internal problem of the unit , there could be some burned parts inside it you may want to to open it up and check it so we can definitely determine the problem..
    President:
  • 2,653 Answers
If you had some functionality we could try a few tricks but with your situation I would consider just buying a new dvd player. They're very inexpensive now since blu-ray is quickly becoming the new format of choice.
You might want to visit the manufacturers website to see if you can get a replacement if it's still under warranty. Most electronic warranties are 1-3 years.
If you have any other questions please feel free to ask.
Thanks!
  • RescueTechLA
    RescueTechLA Feb 23, 2009
    choice.
    You can visit your dvd player's support page here:
    http://www.telefunken.de/index.php?lang=...
    And you can contact them here:
    Tel.: +49-(0)69-600-0
    Fax: +49-(0)69-600-1050
    Thanks!
  • 530 Answers
Hi im josh in cebu phils. may i help you? friend if it only shows power and no function display definitely the problem centers on your display connection. most of the time it will happen when the plastic flex wire or having wire is cut or dmage or disconnected so you try to see these inside it is colore white or blue.check it so that your problm will be solved. good luck vote me so that i wil know if i helped you.thanks
    Genius:
  • 1,226 Answers
Did your try unplugging and then rest for a while (for about 10 minute to 30) and then plug it again and test. sometimes this will resolve the issue.
  • 13,433 Answers
The Dvd player has a major problem(s), seems like the dvd drive is not getting power since it doesn't open.
I would suggest to check fuses on the power board and inspect it theres possibly a problem.
Is the unit covered by warranty? warranty would cover the repair.
    Genius:
  • 1,550 Answers
What is your brand and model details .
Just press the open button two to three times to open the tray .
  • SAM ANDERSON Feb 23, 2009
    Your player is not getting enough power . You need to open the player to find the part which is defective .
    First unplug the unit and using special tools open it .
    And using multimeter check the continuity between the panel elements and on board .
    Before doing this check the condition of fuse ? Is it burned or is it good ?
    If it is good then check the continuity between all contacts point in the player . There can be a loose connection between board and panel.
    Hope this helps .
    For further help feel free to ask .
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
My Sony CFD SO1 keeps skipping/display light keeps flashing
That is an electronic problem. Probably a just-about-to-break cable in the motor of the CD drive, that sometimes causes a short and turns off the unit, or sometimes makes it to comport erratically and produce the buzzy sound. If you have electronics knowledge, then you may open and check the wiring harnesses. If don't, take it to your local electronics repair.
Nov 20, 2009 | Sony Boom Box With CD Player & Cassette...
We have a Samsung Digital Home Theater System HT-DM150. After some guests were fiddling with the remote, we find that we cannot eject a DVD that was inserted. The DVD plays OK, but when we try to eject,...
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jul 05, 2009 | Samsung Audio Players & Recorders
Display reads OPEN LOCK when I try to open dvd tray.
Jun 26, 2009 | Samsung HT-DS610 System
The blue led dont come on when i start up my wii
if the wii still functions, the only time the blue power light is on is briefly when unit is turned on, inserting a disc, or using the power button it will also light briefly when you get a message on wiiconnect24....hope this helps....shia
May 22, 2009 | Nintendo Video Game Consoles & Games
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Battery and software question
You need to have a battery pack inserted in the camera even if you are using computer USB power for webcam use. If your battery is dead, then you are out of luck. Browse battery problem section for my solution to dead battery of this camera.
Nov 03, 2007 | CHE-EZ v:u Digital Camera
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
