Question about HP PSC 1410 All-In-One InkJet Printer
Paperjams while i make a print or copying the paper comes in middle and jams after half print
  • bunty1012 Feb 26, 2009
    catridge cannot move problem and printing blank
Just replace the new original cartridge.
Posted on Mar 08, 2009
Canon pixma mp287
Canon pixma keeps jamming
Dec 20, 2013 | Office Equipment & Supplies
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
My Samsung CLP 310 is having paper jam issue; it prints half and then gets jammed halfway; opening and closing the front panel sends the paper out but upper half of the paper prints ok but lower half shows...
You'll probably have to replace that exit sensor. Cleaning might not do it. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 02, 2010 | Office Equipment & Supplies
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
unplug the usb from the back of the printer. shut down the computer.
Make a copy by placing something on the scanner glass on top and pressing copy.
if it copies that means the hardware is okay.
reconnect the usb and reboot the pc. it would start printing any spooled up print jobs that got jammed when the paper got jammed.
if that dont work look at the bottom right and see if there is a printer icon at the bottom right. if there is double click on it and cancel all pending jobs.
if the copying dont work that means the paperjam killed the printer and you need a new one.
rate if you got a fix . if not you know what happened.
Feb 18, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
take out all the paper from the loading tray, and press down on the inside of the tray 4 or 5 times, and put a sheet back in. There seems to be a physical irregularity with all 2300DL printers that causes this problem
Sep 19, 2008 | Konica Minolta magicolor 2300DL Laser...
Photo paper jamming.
You didnt tell us what phtopaper you use. Especially the weight of the paper! Brother printers are known to have probs with paper thicker then 220g. The paperfeeder cant feed the paper correctly into print position.
another reason might be that the paper isnt placed well into position. Have a look around the FAQ, too:
BTW: If you print a lot of photos it might be cheaper to do that with a (online) print shop.
Jan 04, 2008 | Brother MultiFunction Center MFC-440CN...
HP PSC 2355 all-in-one printer problem
try this:- go to device manager uninstal driver of your printer an restart your machine , now again instal driver of the printer by going to add printer manu.
if this does not solve your problem then try changing your toner/cartridge
Nov 25, 2007 | Computers & Internet
HP PSC 1410 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
