Question about Intuit QuickBooks: Pro 2005 for PC
I am using windows vista. now i want to install quick book 2005 but error exits please first install flash player 7. when i go to install flash player 7. it not support my operating system vista. pla guide me
    President:
  • 2,653 Answers
You probably don't need to install version 7, i'd try installing the latest version instead.
There might also be a install patch on the intuit website or some kind of workaround.
If not it might just be easier to buy a new copy.
Posted on Feb 23, 2009
How to download adobe flash for windw vista free
Download the latest and greatest version of the Adobe Flash Player. After it finishes installing, you go to a site featuring Flash content and are greeted with a message notifying you that you need to install Flash Player, but didn't you just do that? To properly update your Flash Player, you need to run the installation as Administrator. Follow these steps to properly install Adobe Flash Player:
For Vista (32 bit):
1. Open Computer.
2. Navigate to C:\Windows\System32\.
3. Scroll down and open the Macromed directory.
4. Open the Flash directory.
5. Right-click FlashUtil9b.
6. Select Run as Administrator.
7. When the UAC prompt appears, select Continue.
8. Follow the Flash Player installation wizard.
For Vista (64 bit):
1. Open Computer.
2. Navigate to C:\Windows\SysWOW64\.
Once the wizard completes, Flash Player has been properly installed and will now function properly.
Thank you for using FixYa
Don't forget to vote thanks!!
Nov 04, 2010 | Microsoft Windows Vista Home Premium with...
I HAVE QB PRO 2005. I BOUGHT A NEW SYSTEM WITH
Try the latest Adobe flash player here >>>>>>>>>>>>>>>>>
http://get.adobe.com/flashplayer/
You shouldn't have to reboot but i would to be safe then try to install Quick Books again.
Good luck.
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
QB2005 wants flash player 7
Check this link: http://www.brothersoft.com/macromedia-flash-player-59871.html
Jun 25, 2009 | Intuit QuickBooks: Pro 2005 for PC
I can't load quick book 05' I keep getting the same error.
- close all programs
- use internet explorer to open http://www.adobe.com/products/flashplayer/ - download and install flash player.
- run quick book 05 installation again
Mar 22, 2009 | Intuit QuickBooks: Pro 2005 for PC
Problem installing quickbooks pro 2005 software
right click on the install cd and click on QBooks, then setup and it will install withou tthat happening
Jan 31, 2009 | Intuit QuickBooks: Pro 2005 for PC
Can't install quickbooks 2005 - need flash player 7
open the disk file where qb is and look at 3rd party files
then click flash 7 and ignore when it says error
then the darn thing will install no other solution listed works !
but this just did
Dec 20, 2008 | Intuit QuickBooks: Pro 2005 for PC
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Quickbooks 2005 Error 1603
Explore the QuickBooks 2005 CD, go into the QuickBooks folder and double click quickbooks.msi - this will install QuickBooks without checking for the old/outdated Flash Player 7.
Sep 30, 2007 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks: Pro 2005 for PC Logo
122 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
