Question about Barbeques Galore Turbo Classic 3-Burner 207795 (LP) Grill
Motorhome with propane line made for bbq. Bbqs (2 different brands) will light, but wont cook. Flame height very minimally affected by HI-Med-Low setting, but both bbqs work fine on other propane sources, small bottles, other motorhomes, etc. Other propane appliance on subject motorhome works great, propane level not low-no spiders/webs in lines or bbqs. Flex propane line/fittings to bbq works fine on other motorhomes. No quick disconnect fittings in use. Motorhome supply line not clogged as other appliance-(stove in motorhome) works great. All connections checked repeatedly for obstruction, teflon tape reside, other obstructions-none found. Problem 1 1/2 yrs old.
  • Barbeques Ga... Master
  • 3,083 Answers
Are the burners blocked or the orfice or the gas on /off controls blocked
Posted on May 25, 2010
LOOKING FO A NATURAL GAS TO PROPANE CONVERSION KIT.
the change over requires different jets and adjustment of the air shroud around the chamber
there is a process to adjust to get correct flame burn and it is best done by an accredited gas fitter
the jets will be available from any BBQ or out door cooking specialist/ gas shop
Apr 08, 2016 | Grilling
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
New Capt Cook 4 burner - even on Low it goes through 500 degrees in minutes, and there is hardly any difference in flame size between Hi and Low. what's wrong with it - why can't it stay at a low...
I suspect you have a propane grill or it at least the burner orifices are for propane. Because on Natural gas, what you described is virtually impossible. Is it safe to continue to use the grill? Certainly not. Get back in touch with BBQ's Galore dealer you purchased it from (as it's still under Warranty) and have them to either service it or replace it.
Hope this helped you & thanks for choosing FixYa.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Our complex has two Dacor BBQs. Both give off very low heat. It takes 15 mins to get the temp up to 300 and that's as high as it gets. The flame to me look low (weak). Many times the flame cannot make...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 02, 2010 | Dacor Grilling
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Barbeques Galore Turbo Classic 3-Burner 207795 (LP) Grill Logo
498 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
