Question about Epson Stylus 1400 InkJet Photo Printer
All of a sudden my red is printing out oversaturated. And it gets worse and worse with every print. Now my blues look purple, my greens are almost brown. I don't know what to do. None of my settings are different. I've tried restarting. Nothing works. Thank you Lauren
  • laurenjung1 Feb 23, 2009
    Thank you so much for responding. Your answer was very helpful. Rather than ordering a new printer, I'll first try ordering a new CIS. Honestly, mines lasted through 3 refills (saving thousands of dollars worth of ink) which is much longer than I would have expected. There were no pools of ink beneath the cartridges, so I'll keep my fingers crossed.
    Thanks again,
    Lauren
  • Epson Master
  • 419 Answers
Hi Lauren,
It's likely that you have a leak in one of your cartridges that is cross polluting with the other colours.
Given that magenta (red) seems to be the cause I would recommend pulling that cartridge and check inside the area it normally sits to see if there's any obvious pooling or puddles of ink.
Also worth checking all the other cartridges to see if any of these are failing or similar.
This sort of problem can happen with various 3rd party cartridges that are poorly made without many of the valves or flow controls built into the original/OEM carts.
That's not to say that ALL 3rd party carts are bad, just that some should definitely be avoided.
Once you've identified where the excess ink is coming from you'll need to replace any cartridges, clean up any mess in the printhead carriage area (the part where the cartridges plug in) and then do a little printing until most of the polluted ink has passed through the system.
You may also find it's worth blotting the parking pad area that the printhead usually sleeps on for any ink puddling that's built up there.
If you need help with any of these things report back and I'll provide the necessary info... avoid too many cleaning cycles though and take your time.
Cheers
Martin
Posted on Feb 23, 2009
  • Martin Smallridge
    Martin Smallridge Feb 23, 2009
    Ah.... wish I'd known about the CIS... it's likely that the CIS is overfull or is in the wrong position causing an overflow or similar.
    Either way, glad to help...
False colors
Replace the "red" (or the "tri-colour") cartridge.
Jan 25, 2010 | Brother MFC 240C All-In-One InkJet Printer
Colors are off. Browns print green or purple. I
BROWN is made by mixing two of the three "primary" colours.
So, if the printer is out of RED ink, you'll get the "other" primary colour.
Print a "test" page, and verify that part of that page is RED.
Run a printer "cleaning" cycle, and consider replacing the RED cartridge.
Jan 08, 2010 | Canon i860 InkJet Photo Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Red not printing
you try to change your cartridge
i hope i can solve your problem
Aug 30, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Canon MP 730 prints wrong color tones
I was having a similar problem-- what was happening was the print cartridge head seemed to be letting the colors leak into each other. (the science behind this is beyond me!)-- I noticed that instead of being cyan/magenta/yellow, my yellow cartridge had actually turned green, magenta was picking up blue and was turning purple, etc etc. I ended up replacing the printer's printhead and all the color cartridges and then it worked.
You can order printheads online.
Not sure if this fixes the original reason why they got all mixed up in the first place-- if the printer will continue to allow the print head to leak the colors into each other-- but hopefully that's a fixit!
Aug 10, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Epson Stylus  1400 InkJet Photo Printer Logo
164 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
