Question about Toshiba e-Studio 350 Copier
I have toshiva e studio 160, three lights blinkin on panel board - paper, toner,paper jam
  • copiersplusw
    copiersplusw May 11, 2010
    Yes, that would be helpful to know the error. It might be time for a PM too, possibly Drum, but, let's start with the error message first
  • didi2005 May 11, 2010
    I think the machine is in "call for service" mode...
    U can press "Clear+8" button together to check for the error code.
    What is the error code?
  • Toshiba Master
  • 643 Answers
This is a call for service sign.
Press "Clear & 8" to check the error code.
Posted on Sep 17, 2009
Toshiba e-studio 160 error toner,paper,jam
My Estudio 160 jam at the roll out section what can i do
Feb 23, 2012 | Toshiba e-Studio163 Copier
The red light is on and won't print, nothing is jammed and all parts closed. How do I resolve this and get the printer to work again.
Hello A Barr,
Welcome and thank you for using FixYa!
To answer your question: Red alarm lights constitute a full-stop alarm to a printer. These are usually caused by fuser errors, paper jams, and formatter board errors.
I would begin testing by removing the toner cartridge and checking underneath every plastic and metal plate between the paper drawer and the toner cartridge. If you pulled out a peper jam backwards (back down into the paper tray area) you could have paper that ripped off without seeing it. Examine closely.
If you don't find a jam, check the little plastic sensor flags along the paper path. one may have broken off.
If you can't locate a jam, then remove and examine the fusing section (fuser) for torn a teflon roller or paper jams. It is also possible that the bulb in the fuser may be blown out. Chances are a "Maintenance Kit" with Feed Rollers installed properly, will fix your issue. The formatter board would be the last and most unlikely place one would be pushed to examine.
Have a great day!
Oct 10, 2011 | Dell 1110 Laser Printer
HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 30, 2009 | HP LaserJet P2015dn Printer
My HP P2015 reports a Jam when there isn't one
Logic:
Thanks and Regards
Jun 20, 2009 | HP LaserJet P2015d Printer
Led on problem after half wormmingup
Logic:
Thanks and Regards
Jun 17, 2009 | HP LaserJet P2015dn Printer
Printer problems - solid yellow light down on HP P2015
Logic:
Thanks and Regards
Apr 20, 2009 | HP LaserJet P2015dn Printer
Hp lj 2015 jam led stays on
Judging by my personal experience with these printers...if there really is no paper jam, you are most likely looking at a bad formatter board. Very common issue with these printers.
Apr 13, 2009 | HP LaserJet P2015dn Printer
I have HP LJ 2015D all lights stay on except paper load LED, How to fix it
Logic:
Thanks and Regards
Feb 27, 2009 | HP LaserJet P2015dn Printer
What do the sumbols on my hp printer mean
Logic:
Thanks and Regards
Dec 30, 2008 | HP LaserJet P2015dn Printer
Toshiba e-Studio 350 Copier Logo
140 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
