Question about Toshiba B-SA4TP Printer
PAPER JAM WE ARE USING TOSHIBA TEC THERMAL PRINTER MODEL NO B-SA4T-T, WE ARE FACING A PROBLEM OF ERROR AS PAPER JAM, THE PAPRE IS IN ACTUAL NOT JAM PL ADVISE REMIDY
    Champion:
  • 254 Answers
Paper jam on this printer have several causes:
- The size of the label is not correct (The legth mainly)
- The type of Sensor is not correct.
Transmissive or reflective.
- You are using preprinted labels which affects the detection.
To solve this you have to callibrate the sensors for the preprints. Check your manual or contact us.
- there mays not enough contrast between the liner and the labels. You must check the sensors
- Check if the sensors are correctly aligned. You may misaligne the top and the bottom sensors
Posted on Sep 12, 2009
How to solve TEC SA4T Printer's hang problem?
Here you'll find the right driver together with an ultralite version of Bartender distritubted with every new printer.
https://app.sugarsync.com/wf/D1205065_257_623739460
Jun 10, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Paper jam in Toshiba Tec
Check length of label and type of sensor used and check the sensors
Apr 02, 2013 | Toshiba TEC B-472 Thermal Label Printer
B-sx4t keep paper jam, i was replace the media sensor ,sensor cable and mainboard but still paper jam.Any one experience this?
Paper jam:
- The label is not correctly declared.
- Callibarate the sensors (5 sensor adjust) diagnostics menu
- the silicoe support is too thick.
Dec 05, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 paper jam
Size problem or type of material problem or recalibrate the sensors.
All in the owner's manaul
Mar 05, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Feb 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
CALIBRATING THE TRANSMITANCE FEED GAP SENSOR DOESN'T SEEM TO BE WORKING. FOLLOWING THE RECOMMENDED PAUSE, SELECTION OF METHOD (TRANSMITANCE) AND FEEDING MORE THAN 3 LABELS GIVES OFF-CENTER PRINTING AND...
im not familiar with the toshiba printers but i know most others have a way to calibrate using just the paper first and then the label. do you have a manual for it?? if not try and download it from toshiba. are you using a new label supplier? maybe the opacity of the liner is a lot higher on the new stuff?? setting is for sure set on gap??
Aug 06, 2017 | Toshiba TEC B-SX4 Thermal Label Printer
PAPER JAM
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 05, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba B-SA4TP Printer Logo
1,990 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
