Question about Whirlpool Washing Machines
I have a AWM 5050 500 front loading washing machine that is in need of repair, can you advise nearest service center? Silang, Cavite Whirlpool Front Loading Washing Machine AWM 5050 500
  • kerdouglas Feb 23, 2009
    Intermittanly stops and starts
  • fixer444 May 11, 2010
    You can try to google........
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 4 Answers
SOURCE: exactly the same problem
Try fitting clutch kit
Posted on Jul 29, 2009
SOURCE: what year is the Whirlpool AWM 295 Washing machine?
Mine was made in 2000 if that any help
Posted on Oct 16, 2010
  • 6277 Answers
SOURCE: where is the nearest panasonic
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 01, 2011
I have been given a Whirlpool AWM 312 by friends moving overseas and don't know how to operate it and would like to get a manual. My main problem is what drawer (front the left facing the machine) do I...
The manuals for most Whirlpool appliances are available here: http://www.whirlpool.com/custserv/index.jsp . Look for the full model number under the lid on the rim of the washer. AWM 312 is not a complete model number. Next is the washer a top loading or front loading machine? This is actually indicated in the model number - most Whirlpool models start WFW (front-load) or WTW (top-load). The exception is the compact washers (LCE4332PQ is the current model).
For the front-loading washers, the detergent goes into the largest compartment (usually the left-most part of the drawer). Top-loading washers that have a detergent compartment usually have it positioned at the top center back of the tub. Use HE detergent for high efficiency washers and do not use more detergent than recommended (using less is okay).
I hope this helps.
Mar 03, 2011 | Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 221 washer
you will need a replacement heating element for the appliance
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool awm 759 frontload washmachine
be best to have repair man that done it it can be a long job and not finished 4 someone that never done it
Mar 02, 2008 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
168 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
