Question about SYMA Toys industrial Best Holiday Gift: SYMA S002 Swift 3-Channel Radio Controlled Indoor Helico
Spins like crazy
As soon as the helicopter takes off, it starts to spin left like crazy. Could it be the battery?
  • Anonymous May 13, 2009
    the rear rotor isnt spinning making the helicopter spin like crazy. whats wrong
En la parte de abajo del control del lado derecho en la palanca derecha exactamente tiene dos botones uno (l) y otro (r) la (l) es para cuando el heli comiensa a dar bueltas como las manesillas del reloj y la (r) es para lo contrario otro problema que puede ser seria que las palas estan apretadas y tienen que estar flojas con un pequeño desarmador de cruz las puedes aflojar y el ultimo problema que podria ser seria que un motor ya esta mal espero te alla servido estas soluciones.
Posted on Mar 08, 2009
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
My rc helicopter won't fly just spins like crazy
You have posted this in the wrong product category. Please re-post the question in the correct category.
Apr 27, 2012 | Cars & Trucks
One rotor spins when battery is plugged in even if power switch is off.
When the crash happened, was the throttle gimble on the transmitter left at a
throttle up position for any length of time? If it was, it might have burned the
speed control or electronic gyro for the bottom rotor blades. Replacement
of PC Board might be a fix.
Dec 31, 2011 | xheli 9053 Outdoor Volitation Metal...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
Ive a s006 alloy shark remote controlled helicopter and i need to adjust it so it stops spining around but instructions arent clear
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
Apr 28, 2010 | Head Cover For Syma Alloy Shark Rc...
Helicopter spins left and rear rotor does not spin at all
Yes your motherboard shorted out. You need to get a new board or replace the heli.
Jan 10, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
My helicopter spins to the left
theres trim on the remote just hit the r until it stops spinning to the left and it it spins the right then hit the l
Jan 07, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Where can I get copy of instructons - Air SBEGO Mini IR Helicoper
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
Dec 30, 2008 | Sky I Blade Mini IR Helicopter W/ Remote...
SYMA Toys industrial Best Holiday Gift: SYMA S002 Swift 3-Channel Radio Controlled Indoor Helico Logo
623 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
