Question about ASUS A6U Notebook
Power turning off itself when i turn power on
When i'm turning the power switch on, power comes on and just few seconds later the power went off
any help will be so much appreciated
  • 1 more comment
  • gllecherr Mar 29, 2009
    I have exactly the same problem, please help
  • HngnOut4Help May 11, 2010
    So does it like start to turn on, and then turn off.. Or does it turn on and show the starting screen the njust turn off?
  • DEKR
    DEKR May 11, 2010
    on both battery and ac power
    Problem Solver:
  • 16 Answers
It sounds like it's possibly over heating but as you say it's only turning on for afew seconds it could be hardware related, what lights show up when you turn it on ? i would if you have the knowledge to take the back off and clean out the fan or fans as laptops will get hot pretty dam quickly anyways and a blocked or non functional fan will cause the laptop to turn off. it could also be a faulty battery, i've had one laptop from a customre in the past where by unless the battery was taken out or replaced with a new battery it would not stay on also, so try it without the battery installed with the power lead plugged in and let me know what happends. but dont forget the check the fans for blockage or dust and things.
Posted on Jun 15, 2009
Power to instrument panel, door lock, AC went on/off during driving
It appears that you have a bad intermittent connection and those are hard to fix because most of the time, like when you want to work on it, everything is fine! But yes, check the wiring and the switches involved in affected circuits you described.
Sep 13, 2015 | 1998 Toyota Camry
How does my Casio calculator keeping switching itself off after a few seconds?
It is trying to save battery power. Just turn it off yourself when you finish. Read the manual and try to discover if there is a way to choose the idle time before it powers down.
Jul 30, 2014 | Casio Office Equipment & Supplies
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
Proton 320 clock radio won't stay off. Comes back on by itself!
check power switch if not block and i good position. and also monitor by multitester if the continuity of that switch cut in off position.
Apr 13, 2010 | Proton R5A Clock Radio
Today the TV just turned off by itself. I
Its your STK ICS STK 392-110s are Factory ICs use STK392-150s Call Mats 1-800-628-1118
Dec 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Cruise Control tuns on by itself
If the switch is located on the steering wheel, the switch or related wiring could be shorted.
May 11, 2017 | 2002 Chrysler PT Cruiser
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
A95 PowerShot turns on and off until batteries die.
Sounds like you have a stuck power button or shorted power switch. To repair you'll need to remove the top cover. Please see the following disassembly guide. It's in Estonian, but you can follow the pictures.
Continue to page 2, paying particular attention to the second and third picture. It looks like the power switch is connected to the camera through a simple ribbon cable. I'd suggest removing the ribbon cable end from its connector, cleaning any obvious crud, and then reseating the ribbon cable end into its connector. Ribbon cables are notorius for suddenly shorting or getting a bad connection at the connector. Usually just jiggling the cable can fix it too :-) Good luck!
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
By the way, were you the person that left a similar comment on my blog? http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
Jan 31, 2008 | Canon PowerShot A95 Digital Camera
The PDA turn off and it will turn back on immediately later ......
I get much the same, but it comes and goes. For a week or two it will behave itself, then goes pop for a month or three! Do you find if you have external power (cradle or USB) that it will switch off? I also find that if I switch it off from battery power, it will switch itself back on, but then the power switch is ineffective for 6 or 7 seconds. Then you can switch it off, only to repeat the whole excercise again (and again, and again, and again...)
Sep 08, 2005 | Toshiba e740 Pocket PC
ASUS A6U Notebook Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
