Question about New Bright Remote Control Toyota FJ Cruiser
Forward does not work - 19.2 V New Bright Buggy
Reverse works fine and forward stops the wheels suddenly but without transfering to forward direction.
It is a problem with the circuit board. To my knowledge New Bright does not have anywhere that you can order the board.
Posted on Nov 30, 2009
Why does transmission go into forward when I select reverse?
well without a make and model number im guessing completely , but I can tell you if it has a hydrostatic drive the fix could just be a matter of adjustment of your directional control rods
Nov 17, 2015 | Garden
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Fisher price power wheels dune buggy will not work when put in the forward gear but it will work in the reverse gear
check to see if both wheels are spinning in reverse, if not one of the motors is bad or disconnected and this will affect the forward gears
Feb 04, 2013 | Toys
Hi.The mower works fine except it gets very slow and will completely stop moving when reversing up a slope. It is slightly slower in forward as well. The petrol engine is running properly, and all the...
Perhaps you are low on gas and because your tank is tilted as you wheel backwards up hill, the gas line is not getting what little gas is in the tank.
Jan 14, 2011 | Garden
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
Transmission suddenly stopped shifting. It works in 1-2nd &R. Was working fine then would not go forward and would stall the engine. It was like the wheels locked up going forward only, reverse was...
The transmission solenoids are not working properly. Probably requires a transmission rebuild.
I don't think it's in the ground strap or wiring.
It's an internal problem with the transmission.
Aug 26, 2010 | 2002 Chrysler Sebring
How do auto reverse brakes on a trailer work?
Forward Braking
The actuating force for the wheel brake is generated during braking of the towing vehicle, as the trailer tends to overrun and
pushes the drawtube in. This force is transmitted to the expander devices in the wheel brakes via the overrun lever, brake rod,
compensator and brake cables.
As a result, the brake shoes are pressed against the brake drum. The resulting friction from contact of brake linings and drum
produces the required braking.
On releasing the brake on the towing vehicle, the drawtube returns to its original position and the brake shoes are released from
the drums by means of the tension springs.
Auto-Reverse
During reversing the drawtube is pushed in and the brake shoes press against the drum (as in forward braking).
When the trailer wheels are in reverse, the reverse rotation, combined with the friction generated from drum and lining contact,
causes the sliding shoe to slide on its carrier towards the adjuster.
This displaces the sliding shoe radially inwards away from the drum. The drawtube may then travel fully to its end stop without
applying further force to the brake shoes and the trailer can be reversed without any difficulties.
Changing direction from reverse to forward travel results in the drawtube being pulled out, allowing the sliding shoes to be
returned to the forward braking position by means of the tension springs.
From this guide which contains more information also.
Oct 30, 2009 | 1997 Land Rover Defender 90
New Bright Remote Control Toyota FJ Cruiser Logo
509 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
