Question about Compaq Computers & Internet
Connecting my laptop to my new TV
I have a Compaq Presario CQ50 with a VGA output. My new HDTV has HDMI inputs in the back so what cables do I need to purchase in order to show the computer screen on the TV? I have a VGA to DVI cable and a DVI to HDMI cable but was told that there are different types of DVI cables and I don't know which I need. Both of the DVI connectors I currently have look different. Please help!
  • Compaq Master
  • 32,281 Answers
To convert VGA format to HDMI format you need a piece of hardware, check this WEB site.
http://www2.dvigear.com/convert-scaler-video-pc-hdmi.html
Posted on Feb 23, 2009
  • Compaq Master
  • 4,806 Answers
Hi there.
Check on the back of the TV for a VGA input port, if it has what you will need is a male to male VGA lead and a mini stereo to mini stereo audio lead to plug into the headphone port on the laptop to audio in on the TV.
Good luck and thanks for using Fixya!!!
My laptop doesn't have a HDMI port so I have to connect with two cables...I think ones VGA and the other is audio. This goes into the back of my old smaller tv...which is ok but I'd like to route the
Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
Jan 15, 2015 | Computers & Internet
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
Hdmi slot compaq presario laptop input output
It seems your laptop doesn't have an HDMI port. You must rather use the vga port and an auxiliary audio cable.
Jan 22, 2014 | Computers & Internet
Connecting amilo 2727 to plasma tv
Well depending on what output your laptop has and what input your TV has you will have to find a cable that accommodates both.
Common laptop outputs: VGA, DVI, HDMI
Common TV inputs: RGB, HDMI, VGA
Jan 23, 2013 | Computers & Internet
What cable do i need to connect my pannasonic viera px-p42g20b to my compaq presario v6642ea
Hi gmickg,
From what i can see your compaq presario has both hdmi and vga outputs the panasonic viera you have both a vga and hdmi input. Therefore you can use both a vga lead or a hdmi lead. Hdmi also outputs audio therefore it is probably a better choice.
Regards,
K
Mar 30, 2011 | Panasonic Computers & Internet
How do I hook up my Compaq Presario CQ62 laptop to my HDTV LG
If the laptop has an HDMI output - that's the preferred way. However, the VGA is another - then you'll need a VGA cable from the laptop to the TV's VGA input.
Dec 26, 2010 | Computers & Internet
I want to connect my computer to my HDTV
You do not have a hdmi out for this laptop ..so the way to use it to connect to your HDTV is with the VGA out cable ..and using the secondary monitor VGA out ..(basically the standard plug for a monitor ..on the side..
Usually by standard you TV has a VGA in ..so this will not be a issue ..except the fact that you will need a sound cable too ..to connect the sound (jack 3.5 to jack 3.5 )
here is the cables you may need..
http://www.google.ro/search?q=vga+to+vga+cable&hl=ro&client=firefox-a&hs=od8&rls=org.mozilla:en-US:official&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=22fcTvvpF8OI4gSF4eXxDQ&ved=0CD0QsAQ&biw=1024&bih=600
here is the sound cable ..depending on your choice to use rci cable or both ends with the jack if it has a plug like this ..in he TV
anyway you will need the jack 3.5 for the laptop exit of the sound
http://www.svideo.com/stereoaudiorca.html
please do not hesitate to ask if you have any more misunderstandings
Dec 18, 2010 | Compaq Presario CQ50-215NR Notebook
Is it possible to connect my computer with a VGA output to my HDTV with HDMI inputs?
hi there, sure it is.
either check if the video card has two output interfaces(VGA and HDMI) so use the white HDMI-otlet with a cable and your TV, else do get an VGA-to- HDMI adaptor and try connecting the VGA outlet and your TV-set.
Good luck
Sep 13, 2009 | HP COMPAQ Presario SR5410F Pentium...
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Computers & Internet Logo
433 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
