Question about LG MU-60PZ90V 60 in. HDTV-Ready Plasma Television
To start with, I'm working in Afghanistan an we
To start with, I'm working in Afghanistan and we have an LG MT-60pz90v plasma monitor. To find a repair station here is impossible. Our problem is the picture has just started to go out on us (total black screen of death). If you let it set for a day or two, it will come back on but not for long. There are no lines or color changes. Either there is a picture or not. The sound is fine as well. Thanks for any help you can provide.
Matt
  • 5 more comments
  • uh60 Mar 01, 2009
    I will take a look, but it will be like trying to find a needle in a hay stack...Thanks
    Matt
  • uh60 Mar 01, 2009
    I have an LG MT-60pz90v plasma monitor. To find a repair station here is impossible. Our problem is the picture has just started to go out on us (total black screen of death). If you let it set for a day or two, it will come back on but not for long. There are no lines or color changes. Either there is a picture or not. The sound is fine as well. One tech guy suggested cold solder joints?? Thanks for any help you can provide.
  • uh60 Mar 02, 2009
    I have an LG MT-60pz90v plasma monitor. To find a repair station here is impossible. Our problem is the picture has just started to go out on us (total black screen of death). If you let it set for a day or two, it will come back on but not for long. There are no lines or color changes. Either there is a picture or not. The sound is fine as well. One tech guy suggested cold solder joints?? Second tech suggested check loose wiring and burnt capaciters. Noting indicating anything wrong. Thanks for any help you can provide.
    Matt
  • uh60 Mar 02, 2009
    I have an LG MT-60pz90v plasma monitor. To find a repair station here is impossible. Our problem is the picture has just started to go out on us (total black screen of death). If you let it set for a day or two, it will come back on but not for long. There are no lines or color changes. Either there is a picture or not. The sound is fine as well. One tech guy suggested cold solder joints?? Another suggested capacitors. If capacitors are the problem, how to tell which one it is if there is no indications, ie burnt, loose etc..... This system has several caps...Thanks for any help you can provide.
    Matt
  • uh60 Mar 02, 2009
    I have an LG MT-60pz90v plasma monitor. To find a repair station here is impossible. Our problem is the picture has just started to go out on us (total black screen of death). If you let it set for a day or two, it will come back on but not for long. There are no lines or color changes. Either there is a picture or not. The sound is fine as well. One tech guy suggested cold solder joints?? Another suggested capacitors. If capacitors are the problem, how to tell which one it is if there is no indications, ie burnt, loose etc..... This system has several caps...Again, this is a Plasma and "NOT" an LCD. Thanks for any help you can provide.
    Matt
  • uh60 Mar 15, 2009
    Ok,,,I was able to get my hands on another exact model that was working, except the screen has started to go out, but all the boards are working. I pulled all the main boards and exchanged them with my original model and it still is not working. I put the boards that I pulled back into the other one, and now neither one is working. Is there a reset button, or a software loading procedure or anything like this that might be causing the "Black Screen of Death"? Thanks again...Help!!!!
    Matt
  • uh60 Mar 25, 2009
    What are the two (2) switches on the main power board of my LG MT-60pz90v plasma monitor? One can be accessed through a small pin hole externally, and the other can only be accessed with the back cover removed. Both of my LG MT-60pz90v plasma monitors were working a couple weeks ago, and now both have black screens and power up but both screens are black and I was wondering if these could be reset switches, or for reprogramming? Thanks...
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is the video circuit
board.once you have a problem with the video circuit
board this fault happens.so check the video board.
thank u..
Posted on Mar 02, 2009
    Genius:
  • 1,011 Answers
Sir,
Check these links and go through the information
Link 2
Link 3
Thanks Good luck
Posted on Mar 01, 2009
    President:
  • 2,976 Answers
It also mimics a capacitor problem. When it heats up, it opens. When it cools down, it goes back to normal operation.
    Brigadier General:
  • 8,619 Answers
Hi!
Try looking for any loose connections on power supply. Also try and see any burnt capacitors. Also, check for the connections to the lamps. Although, it is not advised to open up your tv but if you want to then before proceeding turn it off for 1 hour so that current can drain out.
Please ask for further clarifications.
Thanks Rylee
  • 10,594 Answers
It seems hardware problem and might be dry soldering in few boards of this TV.
Qualified TV tech can look for cold solder joints to resold them.
Posted on Feb 27, 2009
  • Shahid Electronics
    Shahid Electronics Mar 01, 2009
    You can send this TV to Pakistan for repair if you can not find tech guy in Afghanistan. Peshawer and Quetta are nearest cities to have tech to fix this TV.
    Shahid Electronics Mar 15, 2009
    OK, you exchanged / swapped boards in working TV and all boards are fine.
    Now its confirmed that Plasma Panel is defective.
    Regarding working set, please double check boards connectors, flexible wires that were pulled during board replacement procedure.
    There is no reset switch or software update required as second TV was working fine and got dark-screen problem during boards exchanged.
Turned on went pop now no power
The power supply needs change out, go to www.partstore.com and see if they have one for your set, not that hard to change out, if you are mechanicaly inclind.
Jul 18, 2011 | LG MU-60PZ90V 60 in. HDTV-Ready Plasma...
My 42' LG plasma tv model number 42PC1DA-DU monitor is not show but the sound is working. What should I do?
In this case, the defect is in Y-SUS PCB, change it and adjust the voltage that are specified
on sticker attached to plasma module
Feb 25, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Our LG Plasma is about 5 years old and now it has started strobe flashes really quickly and the colour and picture goes destorted its getting more regular can u please help???
georgiaheasm, I you prove pc not problem, then you or qualified electronics technician will need to troubleshoot units internat power supply for common problems associated with LCD plasma and CCFL back-lit monitors. Look for some DIY videos on YOUTUBE that deal with lcd repair, plasma lcd repair, lcd monitor disassembly, lcd tv disassembly. Look at them even though you will not DIY repair your unit. Good luck with repair. 12fixlouie
Mar 19, 2010 | LG Computers & Internet
I dont have a salushion
Hello change the X-substain Board, and you might consider changing the Y-substain board also. They are starting to fail.
Right now the X-board is faulty.
Dec 21, 2009 | LG MZ-42PZ14 42 in. Plasma Television
TV shutting down automatically after a minute
I also have this TV but mine will not power on at all. Did you ever find a solution?
Max.
Jun 25, 2009 | LG MU-60PZ10 60 in. Plasma Television
Which graphics card should I get to run a panasonic 50' plasma?
A better video card will allow more dimensions like 1440x900 or something bigger, which will make it look better, but it wont make the size of the screen any smaller.
Jan 01, 2009 | Dell Precision Workstation 490 - MT -...
I'm in Afghanistan with the military. We have an LG 60py3rf plasma tv. There is power and sound, but no picture through any input
Hi-
Are you hooking this up on a laptop? try pressing FN key and either f5 or f8 look for an monitor icon on the F# keys on your keyboard and press both twice at the same time or while holding on FN tap on the F# key that has a monitor icon.
Hope this helps, pls dont forget to rate solution, thanks!
Sep 28, 2008 | Televison & Video
No power
i used my plasma 42'' model MT-42PM11 about 3yrs ago i found out after a week that there is black middle bar on the screen how to solve this issue.
Dec 17, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
Oct 12, 2007 | LG MZ-42PZ14 42 in. Plasma Television
LG MU-60PZ90V 60 in. HDTV-Ready Plasma Television Logo
51 people viewed this question
Computer Repairing
Computer Repairing
