Question about Acer Computers & Internet
Not show display
When i connect the power not work display.but green light is being work.
    Champion:
  • 293 Answers
Hi...there,
It's seems you got a busted backlight inverter...
Posted on Feb 23, 2009
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Hello. I just replaced a simple single pole wall switch timer with a CCI 59018. The timer controls our outside house lights and outside vestibule lights. Inside the junction box there were different...
The wires that you describe do not match normal NEC code so you will have to test the circuit to know for sure. The Wires Black should be Power And white is Neutral and Green is green The white wire from the timer and the wall feed and from the lights should be tied together the Black should be connected to the power in the box that you put the switch in and the red would connect to the hot side of the lights, if the wiring was done to code, to the lights you would have coming from the lights one black or any colored wire one white and one green if this is not the colors you have you will need to test with a test meter. Otherwise The red wire would be connected to the hot side of the lights that is being fed. If your not sure of how to do it I will give you the web page of the document to read to set the timer and how to wire it. If you still don't get it to work then I suggest you get an electrician to wire it for you. here is the web page for that timer Hope this helps and thanks for using fix-ya.
http://www.fixya.com/PostAnswer.aspx?thid=6146531&prdid=1467114&ref=unsl
Sep 24, 2010 | Coleman Cable Woods 59018 InWall 7Day...
My PS turns on Green light and all, but my television screen is showing only all black. . .what is the problem?
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor)..
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
Dimension 4500S
hi!,
I hav a solution 4 u . Ur LCD monitor's wires of ur Laptop Has gone loose , U can just give ur lappy 4 a servicing.
byeee........
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
