Question about HP Deskjet 1120c InkJet Printer
HP deskjet 1120c printer does not print -light blinks
Printer was printing, then stopped. Will not print. Went to HP website and tried their ideas. Nothing worked. Wiped off cartridges. Took out and put in again. And other stuff. Power light on, resume light off, cartridge light blinks.
    Problem Solver:
  • 14 Answers
Ok try to add a printer in your computer select local port and it should be USB and the USB cable should be plugged in the computer and select the brand to be HP and the model to be 990c click on next till the FINISH appears and after that the printer will print from the computer
Posted on Feb 23, 2009
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
Hello, My HP deskjet 1120c printer doesn't print any colours any more. Only black and light blue. I bought already 2 new cartridges (colour) and it didn't work. Help me please to tell me what to...
in control panel go to printer and faxes. there you will get your printer in printer tab. right click on your printer model, go to property, to printing preference. there in maintenance tab go to head cleaning. run the head cleaning programme once or twice. your problem will solved. thank you
Aug 30, 2011 | HP Deskjet 1120c InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Cant get printer to work
Try to clean cartridges contacts in printers with alcogol and fabrics. If you can replace cartridges for new. Possible that mode of the workl of your printer is switched in status remitted or is suspended in driver, check it. Pay attention to brightness of the icon of the printer.
Mar 06, 2009 | HP DeskJet 1220c InkJet Printer
Hp deskjet 3940 will NOT print
printer is om light is on not blinking and not printing
Feb 19, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printer not working
my hp 2300jet ink printer not taking paper,green light only blinking
Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
HP deskjet 1120c professional serias printer
I have the same Printer and it works great in Windows XP Pro, so maybe you need to check their website for updated printer drivers...? My Printer is the HP Deskjet 1120C Professional Series Printer, that's the full name so I guess its the same printer...can print up to 13x19 inches....I've used the heck out of mine and it just now developed a problem where it won't pull the paper in from the front, but believe it or not I can load one sheet at a time from the back....
Dec 19, 2007 | HP DeskJet 1120cse InkJet Printer
HP Deskjet 1120c InkJet Printer Logo
284 people viewed this question
Seeker5211
Seeker5211
