Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water
Has anyone successfully fixed his or her water dispenser?
Has anyone successfully fixed his or her water dispenser stopped working problem. I have a two years old Whirlpool refrigerator and the water dispenser stops working but the ice dispenser still work fine. Please give me some advice how to fix this problem. Thanks a lot
  • hohai Feb 24, 2009
    Would you happen to know where is the water switch located? Thank you so much for your help
Check the water valve where your water line goes in make sure both soenoids have power the one closest to the side of the fridge is the water the other is the ice maker
just changed mine 10 minute job
Posted on Aug 24, 2009
  • 40 Answers
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Posted on Feb 23, 2009
At first my Miele CM5000 worked perfectly. When I pressed the espresso button, a perfect espresso would come out- the machine dispensed the correct amount of liquid then stopped automatically. Now, the...
If the espresso coffee outputs too much water and doesn't stop, there is an easy fix. The quantity adjustment for the machine is off. After looking through the user manual, I found out that you could press and hold the espresso button, and then follow the on-screen instructions where you can specify the quantity poured.
Aug 03, 2013 | Miele Cm 5000
Water dispenser stopped working. Water valve works
A major problem with the ge side by side refrigerators with metal liners is water freeze-up inside the door of the freezer. Short term repair is to heat the dispenser area CAREFULLY with a hair dryer right at the point where the water spout comes out.
The long term fix involves installing a heater in the dispenser part number wr49x10173 @$60. The kit comes with installation instructions..
Let me know if you have any questions!!
Aug 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water not dispensing from side by side fridge
check the primary water valve ,does it make a noise when you push the dispenser ?
Mar 29, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge...
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Logo
329 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
