Question about Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range
We have a Smeg dual fuel cooker at least 3 years old.
We have no instructions for the oven controls, and it's not intuitive, so everything is hit and miss.
Can you help?
Many thanks,
Martin Robards
PS
Smeg Spa 42016 Mod SNZ60MFSS ( This does not appear in your list, so I had to guess a model to mollify the programme) I expect it's too old to be listed?
    Novelist:
  • 117 Answers
You might be able to find the associated instructions for your range by calling SMEG at this Toll Free Number: 888-SMEG SVC (763-4782).
I extensively researched your problem and it is truly a hard product to find said information on.
Posted on Feb 23, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For some reason SNZ60MFSS nor SPA42016 does not appear in the SMEG Australia database. Might you verify model number? Thereafter pls check the user's manual available from SMEG Australia here.
Good luck and thank you for using FixYa.
  • 4,806 Answers
Hi there. You can download the free user manual here:
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SUK91MFX5&lang=EN
Good luck and thanks for using Fixya!!!
    Sergeant:
  • 183 Answers
You can find service manual and full customer support on following websites:
Click Here
Thank you
  • sanjay Limbu
    sanjay Limbu Feb 23, 2009
    Or you need to replace heating element on it and if you need quick help the just call at 0844-815-0701.
  • sanjay Limbu
    For live Support
    Chat now
Looking for a circuit diagram
It's usually und the console. A Google search on how to remove the console for your particular make will give you specific instructions.
Mar 07, 2015 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Smeg dual fuel cooker model number UK80MFX1
it sounds like you have a problem with the thermostat that tells the oven to switch off when it gets to the right temperature if the temperature exceeds the setting you choose then the oven will shut down as a safety feature you can get these replaced but because of the age i wouldnt know where to get them from if you get somenody to come and replace it for you it would be cheaper than buying new cooker then this should get your cooker working nrmally i had this problem but on a different make and model but doing this dolved the problem the only problem i did have was locating the right part number but after i got it it only took repair man 1 hour to fit it and done it for less than 50 quid hope this is some help ..................................
Nov 05, 2007 | Ovens
Rangemaster victorians deluxe, double oven , duel fuel
Is there any sort of fan in there - could be some blades hitting surrounding.
Sep 14, 2017 | Rangemaster 110 (Dual Fuel) Dual Fuel...
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg main oven failure
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Apr 01, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
301 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
