Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Fried L7 sub
Can a fried L7 sub be fixed? the face of the sub is hard as a rock what can I do?
  • 336 Answers
Yes it can. Google "speaker reconing" you may need to ship it to the re-coner. Price depends on the size of the speaker. It is ussually cheaper than a replacement. It will take at least a couple of weeks to do the job.
Posted on Feb 23, 2009
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
lets do some diagnosis.. if it's possible, try hooking another known good sub up to the amp and see if that works. if it doesnt, it's an issue with your amp. if it does work though, it's an issue with your sub. or the wiring. if it's a dual voice coil sub, make sure you've got both positives hooked up to positive from the amp, and both negatives hooked up to negative from the amp. if you've accidently got positive from the amp going to positive of one voice coil then to the negative of the other, and the negative from the amp going to the negative of one voice coil then to the positive of the other, the voice coils will be pushing against eachother cancelling eachother's movements out. and this will fry the sub. OR the sub is already fried.
Feb 16, 2010 | Sony XM-2150GSX Car Audio Amplifier
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a kicker l7 12 and it plays sound but its stuck the speaker stays down or stays pushed out it dont move freely is there a way to fix that or can i send it someplace?
kicker gives you a credit if u ship it back to them and upgrade. i have blown several old l7s the new ones are way beter. upgrade i did and am alot happier. the 02 l7s lasted a few months the 08s still going strong with a bigger box and its been 1 1/2 years and no problems. and yes your sub is blown......
Jul 11, 2009 | Kicker 02S10L74 Car Subwoofer
I have a 08 L7 15 hooked up to a 3500W monoblock class D SPL amp, its been working fine for several months until today now the voice coil is fried, what can i do? I also never set the gain more than half...
if it was not a new sub it could had bin used hard and all it needed was one good hit to blow. and if it was new it could had bin a refurbished they tend to blow quick and thats amp is too much of that sub thats good just keep the gain like u have it what ill do go Memphis that is a good 15"
Jul 02, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Good price
Hello smoot_dog,
Well, you did not specify whether you have the 2 ohm or the 4 ohm versions of the L7 and that will impact your choice of amps. But with 8 voice coils and 4 subs to work with, you certainly have lots or potential configurations.
If your subs are the 4-ohm version, I would recommend the Alpine MRP-M1000. Currently it is on sale at for $347.00. With this amp you'd wire the voice coils in parallel (2 ohms), wire each of the 2 pair of subs in series (4 ohms), and the resulting pairs parallel to the amp for a final load of 2 ohms.
If your subs are the 2-ohm version, I would recommend the Rockford-Fosgate Punch P1000-1bd which is stable at 1 ohm. Crutchfield sells it for $349.99. With the Punch and 2-ohm voice coils, you'd series the voice coils (4 ohms), parallel each pair of subs (2 ohms), and then parallel the resulting pairs to the amp for a final load of 1 ohm.
Either of these amps will provide an honest 250 watts RMS to each L7. They'll not only rock your vehicle, they'll rock the pavement.
Apr 14, 2009 | Car Audio & Video
well you can bring it into the place you bought it.. or a place where they sell kicker brand subs.. and ask them for a fix..
they'll either order you another one or.. they'll send it to be fixed.. depends on what it is(note) kicker L7 is made to be taken apart and fixed
Jul 06, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Helpp quick!
My bet on the rock solid sub is the voice coil melted and it is shot. You could just unhook the rock solid one and use the one that still works. Just make sure the impedances will match up. Also, turn the gains down on the amp the sub most likely fried from over driving or distorting for a while. Good luck man
Jun 25, 2008 | AudioBahn AW1251 Car Subwoofer
Brand new sub deied 5 minutes after fitting
maybe u had ur crossover set to full on the amp. Check it bcause, if you have to many high frequencies sent to any subs at a high level u can seize them in minits.
Oct 26, 2007 | Eclipse SW8102.4 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
150 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
