Question about Roper RAS8445KQ Top Load Washer
Roper washer fills with water continuously
My roper washer will fill with water during the wash cycle and sometimes it will fill and fill and fill and FILL! This ticks me off because there have been times that I have thrown a load in just before bed, only to awake the next morning and it is still filling. It drains as it fills...I guess it could be worse. I DON'T KNOW WHAT TO DO! It doesn't always happen, and I am more aware of it now.... but my roper dryer is acting stupid now and I have just about had it! Does anyone have any solutions? Thanks!
  • Gerber2 Feb 23, 2009
    THANK YOU SO MUCH! WILL DO ASASP! =)
    Scholar:
  • 106 Answers
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Posted on Feb 23, 2009
  • fixer444 Feb 23, 2009
    RepairClinic.com (which is good)
    espares.co.uk
    AppliancePartsPros.com
    Try these sites.
New Roper Top Load Washer bought at Lowe's. It grunts like a pig while water is filling. Makes same grunting sound during washing cycle. Is this normal?
If it's new,it's under warranty. Don't try any repair.......call m and get it repaired for free or a refund. don-ohio
Jan 03, 2017 | Roper Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
Roper top loading washer RTW440VQ1 will not stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 22, 2012 | Roper RAX4232KQ Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
Roper Washer
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Oct 02, 2007 | Frigidaire GLWS1233A Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
230 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
