Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Washer Control Board fav6800awq. Need part no.
I need the part no. for the Motor control board -- for the bottom--not for they pad on the top part. Thanks, Rosalina 310-345-8434 mrq@marquiscollection.com 2-22-09
  • Rosalina Chiongbian Feb 24, 2009
    Hi, Tom. We looked at the hoses. Nothing was stuck there. Machine drains well. However, machine is not working still. My husband figures we really need to change the motor control board--located at the base--not the one at the top. Do you know the part no. of the Board? Thank you. Rosalina
  • 318 Answers
As per our phone call i hope you can get this unit fixed by just clearing the drain and that should fix your problem.
thanks tom
Posted on Feb 23, 2009
  • Tom Zwiebel
    Tom Zwiebel Feb 24, 2009
    hi again, the part number for the motor control board is # 25001079 i found it online for about 170 bucks. if you decide to replace it. hopefully it will take care of your problems, but if not then you wont be able to return it as most places wont return electrical parts.
    good luck, tom
Need to reset the program of our maytage neptune TL ver: FAV6800AWQ
""need to reset the program of our maytage neptune TL ver: FAV6800AWQ ""
The only hard reset to the Control Board is to unplug your FAV6800A from the 120VAC service outlet then reconnect.
I feel this will not clear your machine issue. What do you mean by reset the program of our maytage neptune TL?
Apr 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah5500bww washer
Unplug the unit for 5 minutes to reset the control. if the control continues to remain locked, this will confirm board failuer and, you will need to replace this control board.
May 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Problem with FAV6800AWQ model.
Hello jcgraham75,
Just to let you know the control board is a warranty part for 5 yrs. Look in the back of the FAV6800A/9800A Service Manual if you don’t have your original documentation for your FAV6800AWQ. You will find warranty info and the customer service phone number. Have your serial number and model number handy. That info is on the back right side of the console. Good luck
Mar 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Dec 21, 2008 | Maytag Neptune Washer
Maytag Neptune
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Sep 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Rockengirl420@yahoo.com
No motor test required , you need to replce the motor and motor control kit I have appliance experince 5years in the field 9 Times out of ten it is the motor and control board.
Aug 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
The washer stopts immediately after it starts
1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced .
Apr 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
