Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Eletric dryer
My Maytag Neptune just started making a wierd vibrating noise in the back of the dryer while drying a load of clothes. I have never heard this before. It gets quiter and then loud again. It sounds like something is vibrating inside while it is running. What could this be?
  • Anonymous Mar 28, 2014
    The dryer makes a horrible noise when running. It barely spins and sounds like loose rocks inside What is wrong?
  • 686 Answers
A bearing in the back is most likely
Posted on Feb 23, 2009
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag neptune eletric dryer is not drying my cloths only cold air circulates. checked continuity of heat element,good, no limits or fuses open, 120volts to each side of the element. What am i missing?
Should have 240 volts at element.  If it has continuity, you will read the same voltage on either side.  Check across the element for 240.  If you only have 120 check for 240 across the two outside terminals where the cord hooks up.  More than likely either a half tripped breaker or defective breaker.
Dec 19, 2009 | Maytag Neptune MDE4000 Electric Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeze noise, do not dry and drop water from the bottom
Replace: a110f97.jpg
These get loose and rattle make it take fifty forevers to dry the clothes. To get to it you must remove the front. Start here:
Dec 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
740 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
