Question about Yamaha CDC-501 5-Disc CD Changer
My TEAC(model #MC-DX32i)stereo system won't gain power to turn on
I have a TEAC Stereo System and I moved recently and i got into my new place and plugged it in and turned it on and the light on the subwoofer won't turn on which obviously made it so the dock won't turn on. Is it a piece of junk now? Is it fixable?
Fixable as i had the same problem turned it off at the back waited 24 hours and now it works again :) though i have a simular problem my subwoofa keeps cuttig out, why is this? x
Posted on Dec 29, 2009
I own a teac mc-d80 stereo system. When I insert a cd and press play on remote it does not play.Any easy solutions there.Thanks
Laser assembly apparently is inoperative. Time to replace unit since repair is not cost effective.
Aug 19, 2015 | Teac Audio Players & Recorders
My teac mc-dx50i subwoffer wont turn on and its even plugged in
About all you can do is to make sure it has power and input from the main system. Past that, the amplifier in the subwoofer is most likely damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 08, 2013 | Teac Audio Players & Recorders
No Sound for Teac MC-DX32i
Check the speaker wiring on the back for shorts, if okay! the audio output ic is faulty and needs to be replaced.
Apr 17, 2012 | Teac MC-DX32i Shelf System
04 Nissan Sentra recently installed remanufactured OEM Rockford Fosgate stereo. Problem: CD player does not play, displays "error 1"
Sometimes CD players come with a plug that keeps the reader arm in place during shipping. If you don't remove this plug it doesn't allow the arm to move, thus a code. You might recheck this. If that's not the case, check your warranty papers, you might need to use them.
Aug 22, 2011 | Rockford Fosgate Car Audio & Video
After an attempted installation of a new car stereo into my 1990 Toyota Corolla, the clock and the stereo won't work. At first the stereo was working. However, once I secured it into place, I checked...
Did you make sure the harness was plugged securely to the back of the deck? Sometimes if you don't make sure it is snuggly plugged into the back of the deck it can come loose.
Jul 20, 2011 | Car Audio & Video
How do you set the clock
This is on page 23 of the manual for your device... This is the web link...
http://www.teac.com/resources/pdf/mc-dx32i/MCDX32_B_OM.pdf
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
Mar 12, 2011 | Teac MC-DX32i Shelf System
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
Have moved and lost owners manual. where can I get another one?
http://teac.com/resources/pdf/mc-dx32i/MCDX32_B_OM.pdf
Feb 28, 2011 | Teac MC-DX32i Shelf System
244 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
