Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
My Maytag Neptune Electric dryer started a couple days ago making a vibrating noise while I was drying a load of clothes. Sometimes it seems it gets quiter and then louder - it sounds like something is vibrating on the back of it. This just started
  • Anonymous Mar 23, 2014
    I push start at it makes a buzzing noise. Sometimes it will work and sometimes the drum locks up and ownt rotate. If I manually rotate the drum both directions, it will work. If it only turns clockwise, then it won't
  • Anonymous Mar 27, 2014
    dryer started making noisy vibrations, kept getting worse, smelled hot like electrical now the drum doesn't turn
  • 686 Answers
A bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
    Problem Solver:
  • 5 Answers
The problem with your Maytag Neptune dryer vibrating is typically the fan blower wheel. It is plastic and sometimes it will become loaded with lint to create the imbalance other times where it slides onto the motor shaft cracks and it is loose. I have found more with lint, but seen a few cracked as well. The rear of the drum rides on a felt seal, and assuming that is in place the two rear rollers are fine, the wheel is typically the culprit. Jerry.
Posted on Aug 21, 2015
My Maytag Neptune dryer will pop the breaker in the fuse box after running for about 5 minutes. It started a few days ago.
i would first replace the breaker, it is a 30 amp breaker. Just make sure you buy the right type, easiest was is to take the old breaker with you. This should fix your problem if not just let me know and we will go from there, Tim
Feb 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
When I push the on button it makes a noise like its about to start drying but nothing happens. It just suddenly stopped working. All the lights come on but it just makes the sound that sounds like the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is making noise, vibrating and smells like it is burning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fg
Jul 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes squicky noise while drying
its the drum glides/slides that support the front part of the drum open the door and push on the door switch and start the dryer and you will be able to locate the noise source easily
Apr 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytage neptune dryer wont start
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The dryer will not start
heatman101
Feb 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer -5 years old squeeks Now it wont start.
There are four small plastic guide wheels that surround the drum in order to keep it aligned. These will wear after a period of time. The wheels have no bearings, they just ride on a metal shaft. You may either try lubricating the rollers or replacing them. Thank you, Dana
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
983 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
