Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman garage door opener remote failure
I have several remotes to operate 2 doors. one door works on all remotes. the other door will not work if more than 15 feet away from the opener, I have changed batterys and re programed the remotes with no luck, Any help would be great. Todd
    Scholar:
  • 143 Answers
You may be receiving interference. Take all the batteries out of the remotes and try them one by one. You will not have to reprogram them. If you find one shortening the range of the others then get rid of it. Or it may be an outside source. Worst case is you will have to replace the logic board. Thanks BB
Posted on Sep 03, 2010
What could be the problem with garage door opener?
Many openers have a short length of wire that serves as a primitive antenna; ensure the wire is hanging free.
The remote is a radio frequency transmitter, the other end in the garage has a tuned receiver.
Either one of these can drift from their original operating frequency which then can cause the system to fail.
Most modern openers are encoded so that they can resist operating with CBs and amateur radio signals and most require a one-time operation that allows the inside receiver to recognize (and remember) its dedicated remote by its frequency and the unique code the remote produces.
While this principle makes openers more secure, it also allows for more failures of the type you are having.
Take a look at the manuals available at the following site to see is there is one close enough to your model number to let you restore the programming between remote and receiver:
Free Craftsman Garage Door Opener User Manuals ManualsOnline com
Jul 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
I cannot get my universal Clicker by Chamberlain KLIK1U to work with my Quantum 3212 garage door opener even though it says that it works with this model. I have followed the instructions and tried...
The klik1u does not operate at a 303mhz frequency therefore it will NOT program to the quantum 3212 but the actual remote from Wayne Dalton is only 2 dollars more than wal mart charged me for the klik1u when I bought it to try
Jan 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 hp Sears Craftsman Garage Door opener about 18 months old when operating the remote within 5 feet or less of the opener the opener works properly. Upon exiting the Garage about 10-12 feet away...
The difficulty is determining if your remote or the receiver is bad. If you have another remote that works as it should then it is the remote. If you just have the one remote there is no way to tell which is bad.
Jul 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working on Craftsman 53975 garage
It sounds like you have a logic board problem. If your remotes work at all it is not a programming problem. You could pull the logic board and check for loose connections especially around the small transformer. 18 years for an opener is very lucky. Their average life is about 1/2 that.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Code Remote and other remotes do not all work at the same time.
Either your keypad has reverted to an earlier technology and will no longer work properly with your opener or you have the wrong keypad. Either way take the model number off the main unit and get the correct keypad.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
157 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
