Question about Aiwa Audio Players & Recorders
Have a aiwa z2300 karaoke shelf system cd player does read disc also require user manual cd player picks up disc and spins for a short while then replaces is it
2 Suggested Answers
  • 4 Answers
SOURCE: aiwa 3 disk CX-NMT 70 MODEL SPINS A FEW TIMES ON EACH DISC..wont play at all..What can I do? Thanks!!
by the sounds of things le laser it uses to read the disk is faulty which i dont know if u can replace these but thats what it sounds like
Posted on Jan 01, 2008
welcomejee
  • 10594 Answers
SOURCE: AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Posted on Oct 04, 2008
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
The tray of cds does not work properly, does not allow the change of disc to disc and stuck
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd .
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Mar 04, 2009 | Aiwa NSX-A505 CD Shelf System
SHARP cd stereo model CMS-R350AV
your cd player is probably at random and if there is no disc in the cdplayer it would automatically go to the next one
Aug 07, 2007 | Aiwa NSX-A505 CD Shelf System
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
It reads "No Disc" on all 6 settings
How often was the player used? Four years is a typical lifespan of a cheap CD player section if it sees constant use. First, let's see if the player tries to read the disc. Load a disc and listen. Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable. Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word. This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces. You could try to clean the optics. It would involve taking the cover off and finding a way to take a slightly damped swab and gently rub the objective lens on the pickup clean, followed by a drying with the dry side. But, unless the player is prone to dust accumulation (which was a big problem with quite a few Aiwa shelf systems with the 3 disc changers), cleaning it may not help. Another possibility could be that the transmission ribbon which connects the pickup to the player electronics may have developed breaks, which is another typical problem with many shelf systems. Yet another possibility, which is the worst case: the pickup may have worn out. Again, if the player is four years old and was used constantly, it is very possible that the pickup has decided to give up the ghost. Another possibility, which is EXTREME worst case and is not likely to happen at any time with any CD player is a failure of the CD decoder chip. The decoder chip handles the 8-14 demodulation and error correction of the CD signal and outputs the processed signal as PCM for upsampling and conversion. If this chip fails, the CD player will spin up and synch to the disc but, without decoding, the player will be unable to read the TOC and play the disc. But, as I said before, this usually never happens as the semiconductor parts are the most reliable components in a CD player and usually never fail unless they were deliberately damaged by an external influence, like shorting out one or more leads with a screwdriver while the player is powered. In the latter three events, replacement parts may not be easily sourced, if at all, and the required labor to effect the repair may not be worth it. (In addition, a new pickup has a protective solder short designed to protect the laser pickup from static discharge damage. This short has to be desoldered in order to allow the pickup to function.) In this case, replacement of the entire shelf system becomes necessary. If buying a new shelf system, stick with some of the better brands in this area like JVC, Sony, Panasonic, Aiwa, Pioneer, and even Philips. Brands to avoid include Sharp, Sanyo/Fisher, RCA, Emerson, and any cheap store brands like Durabrand or CurtisMathes. But, in general, even the finest shelf systems are a compromise in design which can affect reliability. Most, even from the recommended brands, weren't designed to be serviced very easily when they break as people usually dispose of them rather than have them repaired.
Jan 17, 2006 | Emerson MS9700 CD Shelf System
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
CD's NOT PLAYING
How often was the player used? Four years is a typical lifespan of a cheap CD player section if it sees constant use, and on this specific model i ran across a few cases in which the system died after a few months, and it makes you wonder why the warranty is only for 90 days(the ones i saw)... First, let's see if the player tries to read the disc. Load a disc and listen. Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable. Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word. This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces. You could try to clean the optics. It would involve taking the cover off and finding a way to take a slightly damped swab and gently rub the objective lens on the pickup clean, followed by a drying with the dry side. But, unless the player is prone to dust accumulation (which was a big problem with quite a few Aiwa shelf systems with the 3 disc changers), cleaning it may not help. Another possibility could be that the transmission ribbon which connects the pickup to the player electronics may have developed breaks, which is another typical problem with many shelf systems. Yet another possibility, which is the worst case: the pickup may have worn out. Again, if the player is four years old and was used constantly, it is very possible that the pickup has decided to give up the ghost. Another possibility, which is EXTREME worst case and is not likely to happen at any time with any CD player is a failure of the CD decoder chip. The decoder chip handles the 8-14 demodulation and error correction of the CD signal and outputs the processed signal as PCM for upsampling and conversion. If this chip fails, the CD player will spin up and synch to the disc but, without decoding, the player will be unable to read the TOC and play the disc. But, as I said before, this usually never happens as the semiconductor parts are the most reliable components in a CD player and usually never fail unless they were deliberately damaged by an external influence, like shorting out one or more leads with a screwdriver while the player is powered. In the latter three events, replacement parts may not be easily sourced, if at all, and the required labor to effect the repair may not be worth it. (In addition, a new pickup has a protective solder short designed to protect the laser pickup from static discharge damage. This short has to be desoldered in order to allow the pickup to function.) In this case, replacement of the entire shelf system becomes necessary. If buying a new shelf system, stick with some of the better brands in this area like JVC, Sony, Panasonic, Aiwa, Pioneer, and even Philips. Brands to avoid include Sharp, Sanyo/Fisher, RCA, Emerson, and any cheap store brands like Durabrand or CurtisMathes. But, in general, even the finest shelf systems are a compromise in design which can affect reliability. Most, even from the recommended brands, weren't designed to be serviced very easily when they break as people usually dispose of them rather than have them repaired.
Nov 15, 2005 | Emerson MS3105 CD Shelf System
391 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
