Question about Acer Aspire 6930-6771 Laptop
Turned on the 6930 andwhen it gets top the login where it asks for your password it wont type...thought it was the mouse but when I got the external mouse going I still cant type a letter in the space...
I would try plugging in an external keyboard.  if you don't have one laying around, you should be able to find one pretty cheap.  i've seen basic keyboards for $5 or $10 bucks.  just make sure that you get one with the proper connector for your computer.  (ps/2, the round one, or usb).  If the external keyboard works, then you've got an issue with your internal keyboard and will probably need to have it serviced.
Posted on Feb 23, 2009
I bought a Sylvania SYNET07526 in CVS and everything was working fine. Yesterday I put a password to login to then I turn it off. Today I turned on the netbook and asks me the password but do not let me...
Hello, I think you can plug in an external keyboard in one of the usb ports on the side (not the back ones) One is for an external mouse, and one for a keyboard.
If you have an external keyboard with a usb plug on it, try plugging it in and entering your password that way.
Doesn't everything bought new have warranty of some kind?-It does in the UK anyway.
Kind regards,
nicam49
Jan 11, 2011 | Sylvania G-Netbook
I am unable to locate the bluetooth setting on my acer 6930. I am trying to use a bluetooth mouse and the button to 'turn on' the bluetooth function is not working. I have tried to locate the bluetooth...
You didn't list an operating system but as I have a 6930 with Vista, I can give you what I know based on mine. If you go to Control Panel - Bluetooth Devices, you will find options to add bluetooth devices and a settings button for devices you have added. However, the 6930 does not come with bluetooth built-in, just the capability to turn it on and off. If your mouse did not come with a bluetooth adapter for the computer, you'll have to get one separately to use your mouse.
Apr 25, 2010 | Acer Aspire 6930-6455 Notebook PC
I have an Aspire 6930. The screen has become damaged when something fell on it during an airline flight. The lap Top works OK when hooked up to an external screen, Is there any way to remove the damaged...
It is not that much practically easy to remove the damaged screen including the lid. Instead, you can get an external mouse and keyboard, connect it your laptop and can use them while keeping your laptop lid closed. For this you need to hook up your external display and in the control panel -> power options, by default the settings will be there to put your computer into sleep mode when the lid is closed. You have to change this option such that when lid is closed nothing should be done.
I hope the provided solution is useful to you.
Thanks
Mar 30, 2010 | Acer Aspire 6930-6455 Notebook
My acer 6930 boot up but screen stays black with
Try this fix...
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Oct 08, 2009 | Acer Aspire 6930-6771 Laptop
Type on keyboard but nothing happens
in back of the computer swap the mouse plug with the keyboard. That usually works
Apr 14, 2009 | Computers & Internet
Keyboard not working
is this a windows login password or a boot password
you should have Fn key on keyboard
and another coloured key to correspond for turning on keyboard press Fn and the other key simultaneously
Could be fn f3 keys
if you just bought you may find it in your manual
please let me know if you still need help
if you have a switch above scroll pad you may have shut that off but all models don't come with that option
Feb 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Volume Wont Turn Down
check devices and make sure your drivers have no errors
check settings for mouse and keyboard in control panel
and check audio settings in control panel
maybe your mouse pad needs cleaned
Jan 22, 2009 | Acer Aspire 6930-6771 Laptop
WD 2 TB external HDD asking for password
log in from administrator see if your anti virus's or your windows fire wall is not interrupting if not solved go to run in the start menu type command "chkdsk" "netuser administrator (the password you want to give)"
Jan 20, 2009 | Western Digital My Book Essential Edition...
Acer Aspire 6930-6771 Laptop Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
