Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
I bought a asus 256mb en7200 gs graphic card it worked fine for a month but since two months it is not working properly it just get hang when i start my pc when coming to desktop or in games and restarts automatically. what is the problem ?is it cooling problem if yes please let me know how to solve this
  • jamesbond_bo
    jamesbond_bo Feb 24, 2009
    it also sometimes displays a blue screen message just a blink and restart !!!!!!!!!!!!!!!
If the problem occurs right as the windows desktop comes up from a cold boot, it is not a cooling problem, the card hasn't had time to heat up yet.
You probably have a bad driver, download at http://support.asus.com/download/download.aspx your series = Nvidia, model=en7200 series and install new drivers.
Also, check to make sure the card is fully inserted in the AGP slot, I've seen some odd things happen because of a loose card.
Posted on Feb 24, 2009
I have 256mb pci xpress en7300 gs geforce graphics card of asus company some moths ago its working but one day when i on my pc it cannot dislpay anything monitor light remain yellow but from other slot of...
Hello sifian_786, did you try to uninstall old video driver and restart computer and go to nvidia website and download latest driver for you video card and install, restart computer this should solve problem you have, are you trying to run dual LCD monitors ?
Nov 24, 2010 | ASUS EN7300GS/HTD GeForce 7300 GS, PCI...
My Asus EN7200 GS stoped working, lines appeared in my monitor
you must be reset your bios put on jumper coms clear choice 2-3 then reset configure position again 1-2 then computer is ready activate built in agp
Thanks
Nov 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Have 7200 GS PCI-E and after working fine for 18 months, am now getting flickering intermittent black horizontal lines on my lcd monitor. suspect the graphics card as monitor tested fine on another pc....
Take out the graphics card and clean the contacts on both sides (a rubber on the end of a pencil is good for this) and retry. If possible try the graphics card in another computer.
If all this fails - get a new card!
Nov 03, 2009 | Nvidia GeForce 7200 Graphic Card
GeForce 8600 GT 256MB DDR3 PCI Express Graphics Card doesn't work
contact the shop / place you purchased it from and they should be able to give you info of where to send it and what to do - they should have a section on there website where you can go through the return process and you will most likely need to get an RMA number to authorise the return / replacement.
Apr 11, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
I have a asus 256mb en7200gs graphic card it worked fine for a month but now it does not work when i install it with it's drivers it installs and after restarting my pc it just restarts just after coming...
remove the card, get the old drivers for the motherboard and reinstall them, then see if you can get the system running, if the problem continues to reboot every time you are going to have to reset the motherboard this means shorting out the bios and setting everything back to manufacture orignal setting, before doing this go in to bois and write down everything on the type of drive and all the information on that line
cyclinders
heads
precomp
sectors
lba
so one
how the systems boots firsat hd, dvd, cd, floppy
on the motherboard is a sitch 1-3, most of the time it is on 1-2, you need to move the switch 2-3 for a few seconds and move back to 1-2, reboot
go into cmos
set up everything the way it was before you reset the system everything should work fine
reinstall the video card and drivers
disabling old drivers
Feb 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
My pc starts hanging and after that restarts
THE PROBLEM IS THE POWER SUPPLY MAY NOT HAVE ENOUGH POWER TO SUPPORT THAT VIDEO CARD.
THIS VIDEO CARD IS CAUSING THE PWR SUPPLE TO OVER WORK
THE MOTHERBOARD IS EFFECTED BY THIS TO.
CAUSING RAM TO OVERHEAT ALSO.
NOT ENOUGHT AIR FLOW THREW THE COMPUTER SYSTEM.
THE BIGGEST KILLER FOR PERFORMANCE IS HEAT.
YOU NEED ADDITION COOLER IN THE SYSTEM TO COOL THE POWER SUPPLY,
VIDEO CARD, RAM, CPU.
HERE IS A COMPANY FOR THIS PROBLEM YOU ARE HAVING
WWW.ACOUSTICPC.COM
THEY HAVE LOTS OF DIFFERENT COOLING AND COOLER DEVICES FOR COMPUTER SYSTEMS
ROD
Feb 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
I have a asus 7200 gs 256mb graphic card my pc keep restarting
Your PC keeps restarting because while playing your video card is highly solicited,and this causes overheating. The solution to your issue is to buy a cooling fan and attach it to the cooling grid.
If this solution worked for you please rate it. If you require further assistance feel free to post a followup comment.
Feb 13, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Pc restarts in between the games
is it summer now there? It sounds like heating problems. If you keep the system very cool does it still do the same? (Try opening your side panel, and putting a fan in front of it, blowing into your case, also check to make sure that the fan on the gfx card can spin freely and isn't hampered by dust particles. Also do you have thermal paste? i recommend taking your cpu heatsink off, wiping off the old paste, and applying new paste. I've seen thermal paste get old and then cause this kind of problem. If that still doesn't work, try drivers like bunny recommended. Good luck! :)
Jan 04, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
189 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
