Question about Roper REX4634KQ Electric Dryer
Tdc 32 dryer not getting hot anymore Grrr.... loads and loads of baby laundry to do and husband needing clothes for 3 day business trip!!!!! My stupid dryer just HAD to start acting up now!!!!!!!!!!!! Turns just fine... but not getting hot and not drying.
  • 2 more comments
  • Gerber2 Feb 23, 2009
    Thanks so much! I kind of thought that something needed replaced after pulling the dryer out last night and cleaing the excess lint from inside the dryer, the hose and from outside. Unplugged it and plugged it back in and shut the breaker off too. After all that I knew that it was not due to lint build up. I just could not remember the name for the possible problem. HEATING ELEMENT! Thank you so very very much! =)
  • 2jesse1 Mar 03, 2009
    I have model rel4632blz Roper dryer and it will not heat up although the heating eliment is fine and the thermostat is fine. What else could it be? I also had to turn the timer knob around an extra time or two for awhile before it quit heating all together.
  • Anonymous Mar 09, 2009
    i changed my heating element the dryer worked for three loads then stoped heating again
  • frogsforever Mar 09, 2009
    i changed the heating element and the dryer works for a little while then stopped heating what next
  • 547 Answers
Heating element http://www.partstap.com/ go here for diagram on how to install and part
Posted on Feb 23, 2009
Dryer stay hot
It's very possible your element shorted to ground causing the element to get constant currant from the wall outlet if it was hot without running, if thats the case you need to replace the heating element.
Jan 15, 2014 | Dryers
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Dryer gets too hot on regular laundry setting but seems to work ok on delicate laundry setting.All vents and filters are clean.When using regular setting when drying is done the clothes are too hot to...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 06, 2011 | Danby DCD5505W Electric Dryer
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
HELP
HELP
HELP
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Front loader locks, but nothing else. Please help!
ck to see if water still in tub if so remove as much as possible then remove bottom cover and clean pump..if you are washing baby clothes use mesh laundry bag for small items such as socks they tend to plug up pumps easily
Nov 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
thermostats.... 2 of... (cut out & one shot)
Mar 30, 2008 | Hotpoint TDC32 Electric Dryer
Roper REX4634KQ Electric Dryer Logo
113 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Roper Dryer Expert? Answer questions, earn points and help others
