Question about HP (5185-6477) Motherboard
My cpu wont turn on
When i turn my pc on nothing happens but the motherboard light flashes the fan doesnt even come on
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend nothing happens to your motherboard or cannot completely open when the supply current is not enough to support or provide the mainboard.especially if there are many devices attached such as video cards dvd rm etc. you need more power to make them work. so you need to change or use a power supply having a output.500w up.for better good luck hope i helped you.vote so that i'll know if i did it so.
Posted on Feb 23, 2009
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open...
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Changed the CPU fan and now the monitor won't turn on. Power light stays green, and harddrive light stays yellow. Fan is running.
its not problem of fan. re-insert your ram. even if doesnt come then problem with ur motherboard chipset. if in blore call 9972888885
Jan 21, 2010 | Compaq Presario S6000CL (DT072A) PC...
Gateway 507gr wont power on but looks like ps unit is good
Make sure you are plugging in your P.S. to Motherboard properly. This can happen if you are off by one pin on a 20 pin Supply on a 24 pin Motherboard. If you never opened the case and it just started happening, maybe one of your cards came out of its slot or your CPU Fan is not running.
Nov 06, 2009 | Gateway 507GR PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
No signal to monitor.......all dark
and im sure the screen appers to be blank and the key board lights flash once and no feed back other than the fans spinning right? . this is a common problem with asus motherboards and AMD cpu's which indicates a bad motherboard or cpu if you have acces to anouther cpu try changing to that one if that doesnt work you're motherboard is gone
thank you
ace
Dec 11, 2007 | ATI Asus P4R800-V Deluxe Radeon FSB800...
The laptop doesnt start up. cooling fan is brocken. thermal oil is old and almost dry and little
Sometimes depending on the version of BIOS there is a thermal shut down feature,If the CPU gets to hot it will shut the entire system down.What you can do is replace the CPU fan and apply more grease in between the heat sink and the CPU chip.If this does not solve your problem then you may have damaged the CPU.the best way to fix this is to replace the motherboard and CPU.Try replacing the fan first because if your computer has the thermal shut down feature then chances are that it protected the motherboard and CPU from any damage.Try the simple things first! GOOD LUCK.
Nov 13, 2007 | Toshiba Satellite A45-S250 Notebook
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
HP (5185-6477) Motherboard Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
