Question about EliteGroup P4VXASD2 Motherboard
Power button connection
I don't know the designation of panel 2 of the p4avxsd, i can't connect the power button correctly
    President:
  • 2,110 Answers
  • 530 Answers
Hi im josh in cebu phils. friend connecting power button is very simple problem. all you have to do is look for the slot in the mainboard having 2 pins named pwr swtch then mount in the 2 wire black and red.then thats all. good luck. vote me so that i wl know if i helped you.thanks
Posted on Feb 23, 2009
What are front panel connections on motherboard?
Font panel connections are the power and reset buttons and status led's.
front-panel-connections-motherboard-u2of3ikpdsr23qnsqxf3hbc3-2-0.jpg Ignore pin 9
The color order on the reset and power switch are not important but see that you insert the colored cable to the power led to pin 2 and the colored cable for the hdd led on pin 1
Oct 05, 2015 | NEC Galileo 845GL (N4-IBFGL) Motherboard
HP Designjet 500 has a locked screen. I have been trying to get the plotter to run on our new computer and it locked up after installing the current Firmware and driver updates. Any suggestions would be...
Dear Friend, It's a serious issue what I understood & confusion is control panel locking facility not avail in this model, how its locked?.. Simple method to catch the faulty part through power LED behaving s..(Power led located on power button)
# LED is OFF - This indicates that the Power Supply Unit is
completely dead. Try the following:
1 Check that power cord is connected correctly to the Printer and to the Power Socket.
2 Replace the Power Supply Unit
# LED is ON (all the time) - This indicates that the Main PCA is completely dead. Replace the Electronics Module
# LED is Flashing - A problem has been detected with the previous firmware upgrade. Try re-send the firmware upgrade file.
# LED Flashes twice every few seconds - The Printer cannot detect the Interconnect Cable. Try the following:
1 Check that the Interconnect Cable is connected correctly to the inter connector PCB & Electronic module.
2 If the Interconnect cable is connected correctly and the LED continues to flash twice then replace the Interconnect Cable
LED Flashes 3 times every few seconds - The Printer cannot
detect the Front Panel. Try the following:
1 Check that the Front Panel is connected correctly to the Interconnect PCA.
2 If the Front Panel is connected correctly and the LED continues to flash 3 times then replace the Front Panel
LED Flashes 4 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module
LED Flashes 5 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module.
Now U decide that whether firmware uploaded properly or not?..if not its sure that Electronic module gone.. you have 2 replace it..
Any further help/query pl reply, best of luck..
Oct 02, 2013 | HP DesignJet Office Equipment & Supplies
I just reconnected my kds monitor and it does not come on I only have one cord and it connects to the computer should there be another power connection. Don't know where my skematic for this monitor...
you can get the support information on the monitor from KDS here
All monitors have at least 2 connections, 1 power and 1 data cable (Some have multiple data input options all have at least 1)
In most cases the power is a standard 3 pin PC outlet cable (Same cable as a desktop computer uses) some more compact designs us an AC adapter and DC input similar to a portable computer.
If you post the exact model I can post a more exact answer
Nov 03, 2011 | Computers & Internet
Hp T-610 gives an error code of 08:11. Can I get some help.
No comunication between the Front Panel and the Main PCA. If you don't know what you are doing, Get a printer tech to check it out. If you do know what you are doing....
Corrective Action: Try the following: 1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer. 2 Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel. 3 Check that the connections between the Formatter and the Main PCA are not damaged and are correctly connected. 4 If the System Error continues, replace the Formatter. 5 If the System Error continues, replace the Main PCA.
Aug 15, 2011 | HP Designjet T1100ps Printer
Can't get cd player to work in my ub802 mixer.what am I doing wrong.I have connected it via RCA cable from cd player to mixer tape in .is this correct.I also have the mixer in tape out and phantom...
Phantom should ONLY be on if using CONDENSER mics or a DI box requiring phantom power... yours should be OFF. cables should be correct. The 2 Trk to mix button should be down.
Jul 04, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I'm trying to connect my Wii console to an old magnavox tv my aunt gave me. I don't know how to connect it because it doesn't have the tv/video button on it. I've tried reconnecting...
U have the tv original remote?Look for a button said Input,used that button push it to goes into video mode 1 or 2.Don't have the tv original reomote.Try website like Remotes.com to buy the tv original remote.
May 08, 2011 | Televison & Video
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Jun 22, 2008 | Denon AVR-1907 Receiver
Power button wiring help
Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 15, 2007 | ASUS A8V Deluxe Motherboard
EliteGroup P4VXASD2 Motherboard Logo
350 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
