Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrigerator My refrigerator (ge Model tbx182kb) keeps my food cold for a short time. However, it still sounds like it runs. Any ideas?
  • gobcp Apr 17, 2009
    Wow the same exact thing happened to my GE Frig with the mother board. The Frig was only 4 years old. I went out today and bought a LG which is Korean. GE is American what does that tell you?
  • Anonymous Mar 18, 2014
    refrigerator is keeping things cold but it keeps starting runs a short while and repeating the same process
This happened to me with my side by side. The repair man came to my house, said that GE have cheap refrigerators because they are not meant to last very long. The mother board that controlled the temperature went out. A component in my freezer would get frosted up, but the heater would not kick in to reduce the freezing. Everything starts to warm up in the refrigerator as a result. A new motherboard would get the refrigerator back in timing.
Posted on Aug 21, 2007
GE Profile refrigerator does not get cold enough to keep food. The compressor is humming but even after having it plugged in for 3 days it has not frozen anything or kept any of the food cold.
Could be the t stat not shutting the unit off..so it runs all the time untill it freezes the evaporator in the the freezer then it runs and runs and gets hot...or if it has had a compressor replace before..the freon level what not put back in thr right way..meaning its overcharged, or undercharged..this will also do this...The coils are dirty under the unit...
May 29, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE GTS17JBSBB makes chirping/tapping sound
thats not a fan noise. to me, sounds like pressure going thru an expansion valve. you better get on an appliance thread website with that one. meantime....loose mounting of condenser pipe or evaporator outlet???
Nov 19, 2013 | Refrigerators
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
I have a GE SxS model number gss22jepabb that doesn't keep the refrigerator part cold. We have replaced both thermistors in the freezer and last night the motherboard. Refrigerator is still not cold and...
Close the doors and look to see if the fresh food door is down lower then the freezer door. If it is adjust the fresh food down up until it is at the same level as the freezer door. The reason why I suggest this is hard to explain but it is a legitimate repair. This page does explain http://www.appliance-repair-it.com/GE-refrigerator-repair.html Look under the section titled damper/door switch.
Sep 28, 2010 | GE Refrigerators
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, Iam having trouble with the refrigerator. My refrigerator is a side to side door fridge. The freezer works but the other side of the fridge halfway to the top is not leaving the food cold only the food...
sounds like your evaporator fan motor is not running. when this happens the cold air is no longer circulated, so it falls toward the bottom of both sides. in addition, your iceamaker may stop making ice, and the water dispenser may stop dispensing water through door.
However, due to an issue with the fan motor itself possibly causing a short with the mother board, without testing properly, my advice would be to replace both the fan motor and the mother board.
For general refrigerator questions, visit my website: www.FixMyFridge.net
Mar 17, 2010 | Refrigerators
GE model GSS22JEMDWW. Replaced the compressor six
check the RTX overload on the compressor body its bad and trying to start the compressor
Dec 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Why does my ge fridge run too cold?
Sir,
You are suggested to try lowing down the Thermostate of you Refrigerator.
Oct 21, 2009 | Refrigerators
Refrigerator not cooling
If it has a filter on the bottom, make sure that is clean.
Dec 21, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
244 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
