Logitech Quickcam Chat Webcam for Skype - Web camera - color - audio - USB
Problem for Logitech Quickcam Chat Webcam for Skype - Web camera -...
Logitech quickcam - Skype -video and audio don't work
By karin168 on Feb 23, 2009
My mom has a logitech quickcam E3500, the camera is installed, and when tested in Skype, it works fine. However, when trying to chat, the webcam does not connect to Skype (video and audio).
The error message is: Skype can't connect to webcam temporarily.....
What's the problem??
Same Problem
May 12, 2009
-   My peoblem is very similar.
The webcam tests OK when connected to Skype, but when I attempt to make a video call there is a loss of video or audio. Only occasionally has it functioned correctly.
Any solutions?
-   jort
Feb 25, 2009
-   I have Logictech Quickcam 3500, installed necessary software. Cant make any video calls through skype, skype does not recognise webcam!!-   Guest
Solution #1
posted on May 28, 2009
Somewhat Helpful)
yooperbud
Rank: Wiz  Logitech Computer Accessories  Expert
Rating: 82%, 2103 votes
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have there computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
  1. On the VIM sign-in window click on Edit.
  2. Then click on Settings Enhanced IM.
  3. Next click on Enhanced IM.
  4. Then click on Audio Video.
  5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone Speaker
Camera The audio and camera should function now.
Additional info to use with VIM settings.
Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
  • The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
  • Images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Comments:
Jun 24, 2009
- Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
A. Skype Setup:
B. Yahoo Setup:
Jul 02, 2009
- Normal 0 See section A. Skypein the info below to setup the Audio & Video.
A. Skype Setup:
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/ ) set it up as follows:
  1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
  2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
  3. Just below that, go to the Test Audio section and (in blue writing) click on Open the call setup assistant” and follow the instructions on the left window.
  4. Then after completing the Audio Setup, go to down and click on Webcam it should BRODCSAST and you will see your picture.
  5. To Chat, click on MESSENGER and then
  6. After make necessary settings, click on APPLY, then OK.
  7. Then click on MESSENGER and go to my WEBCAM ready to use.
  1. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
Sep 13, 2009
- See section A. Skype in the info below to setup the Audio & Video.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Microphone
Speaker
Camera
Additional information to use with VIM settings.
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Properly. Follow the on-screen prompts.
Notes:
Picture-in-picture (PIP) display.
Sep 18, 2009
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Was this helpful?
Yes
No
Popular Solutions for Logitech Quickcam Chat Webcam
Questions and Unsolved Problems for Logitech Quickcam Chat Webcam
Do you recommend Logitech Quickcam Chat Webcam for Skype - Web camera - color - audio - USB?
Answer
Answer
My connection is droped after 40-50 seconds with my web cam and skype
Answer
i have a sony vaio laptop and when i use skpe the connectiond breaks immedialty so i cant use my... (More)
Answer
I attempted to follow your guidance but Im not sure which settings I should use and how to do the... (More)
Answer
I have a Logitech Webcam Pro 9000 and am using it with Skype but seem to have a problem. It will... (More)
Answer
I was unable to have my family see me on Skype. What must I do to get the problem solved?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Web Cameras Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
