Question about NetGear WGT624 Wireless Router
Problem with internet working with router.
My daughter has a laptop. We have a netgear router. Her computer says connected, but it will not pull up the internet.
  • Anonymous Mar 13, 2009
    I'm having this same problem. Up until monday my laptop was connecting to the internet just fine. Then I turned it on on monday, it says I'm connnected to the internet, even long enough for vista to pull up the weather and my homepage, but when I try to go anywhere, or try to connect to any online games, it just hangs up and stops working. The other wireless computer in the same room is working, and when I brought my laptop to another secure network it worked there as well.
  • rheimberg May 11, 2010
    on the router, in the status page does it say connected to internet?
I had to turn off WMM on the router. One computer supported WMM so it worked fine, but the others didn't.
Posted on Mar 27, 2009
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
Laptop can not connect to netgear wireless router
I would suggest using the network setup wizard, in the control panel. Best option is to copy the data to a pen drive and transfer to your daughters laptop.
May 30, 2010 | NetGear WGR614 Wireless Router
Every time my daughter uses her laptop, my pc says
Either unplug the router from power source for 10 seconds and plug back in to reset.
Or you may have an ip address on the pc itself that is conflicting with your daughter's ip address. Dynamic ip address are set so they don't interfere with each other. We use 4 different pc's on one router in our home.
You can change the ip address of your computer by going to start menu, then run, then type ipconfig /release, then type ipconfig /renew and it will give you a new one.
Or you can access the software and settings of the router itself by opening up an internet page, go to address bar and type 192.168.1.1 and hit enter.
It should bring you inside your router so you can check and switch any settings.
Nov 17, 2009 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Everytime I want to use the internet I have to plug in the ethernet cable from the router- WPN824- and go the the 192.168.1.1 address and setup the wireless setting. Then I can disconnect and use my laptop...
Netgear routers are notorious for this. The firmware on the unit just loses connection. In order to fix this, you have to make sure that you have the latest firmware.
There are several version of your unit. go to the following page and download the firmware and update it to the latest non-beta release.
http://kbserver.netgear.com/products/WPN824.asp
Aug 04, 2009 | NetGear RangeMax WPN824 Router
Internet want start
Hi mtaylor9,
Routers are great but they do have issues with distance, or certain walls that can interupt the connections. My suggestion is to have your daughter when she is connected to walk away from the router step by step, and continue this until it drops. This will give you the distance it will work for you. Then either move the router closer to her destination, or you can get another router than can act as a passthrough. The last option is to run ethernet wire everywhere which really defeats the purpose of wireless.
Good Luck
Mark
Feb 23, 2009 | NetGear WGR614 Wireless Router
Laptop wont connect with internet.
Is your desktop wireless as well? If so plug in network cable to Hub. You shoude be able to connect now.
Check WPA and you should be good to go.
If this does not help then ping the router and let me know the response.
click start-->Run--> type CMD--> press enter.
In the command window type...
ping 192.168.1.1
tell me what return you get.
Feb 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
Internet connection
What type of internet connection do you have? (ie. Cable, DSL)
Has your setup worked in the past or is this a new setup?
Dec 20, 2007 | NetGear WGR614 Wireless Router
NetGear WGT624 Wireless Router Logo
152 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
