Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washing machine spins but still leaves the clothes soaking wet
  • fixer444 May 11, 2010
    Check & clean out your filter
    Possibly your filter is clogged or your pump is. Clean out the filter first.
  • 77 Answers
Check for blockage on the filter
Posted on May 08, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
302 people viewed this question
Dan Webster
Dan Webster
Sal De
