Question about Ruud Central System Air Conditioner
Unbalanced cooling or heating
My thermostat is installed in a small hallway just before entry into master bedroom which is only room on that side of house. When the heat is on the other side of house is to cool and when Ac is on the other side is warm. There is a large living room then entry into a hall way with 3 bedrooms. I have always felt that the thermostat should be mounted in the living room or in the other hallway. The return air is right below the thermostat.
John
    Scholar:
  • 144 Answers
You need to balance the system. It's a matter of adjusting the dampers or registers so that you have a little less air flow near the T-stat and more to the other end of the house. Likely you have a return vent near the T-stat. That return draws air to it and likewise the T-stat. If you are getting a lot of air out of the registers on that end of the house damper them to force more air to the other end of the house. Do not close them entirely though. You may have to play with it a little to get it right. I hope this helps. Please remember to rate Fixya rate me.
Posted on Feb 23, 2009
Room Thermostat--Right near heater
First move that fridge!! Constricting the airflow like that not only makes the heater cycle too much... it's a safety hazard.
Once you allow the heat to circulate properly you can address the issue further.
Oct 26, 2013 | Heating & Cooling
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
Tip
How to cool big home with small air conditioner(s)
A lot of people have only one or two rooms that can take an air conditioner in the window. Often times, the air conditioner is also rated at a cooling power that would make you believe that there is no way that it can to cool the whole house/apartment. You can crank it to the max to try to cool as much as possible, but then this makes one room too cold and the others still stay too hot. You can try blasting the cool air down a hallway with a fan on maximum speed, but that only works so well. And, it's noisy, too. Well, I have two 260 sqr ft rated room air conditioners and I am cooling 2000 sqr feet of house to a comfortable 72 degrees in all rooms and it's been 95 outside all day. How to do it?
The trick is setting up your home to take advantage of laminar air flow. Set your air conditioner to say 68 degrees and start it in the middle of the morning before it feels hot outside. Put the AC deflectors pointing downward and towards the door. Put fans in the doorways pointing out of the rooms that have the AC. Point them level to the floor (not up) and put a fan to one side near the end of long hallways. Set the fans on the lowest power setting (not high). If the hallway branches out into a bigger room, put a fan in the room that is blowing across at a right angle to the entry, pointing the air flow parallel to the wall. This will circulate the cool air around the room. Keep the fans on low and pointed parallel to the floor, not up!
What you have created is a re-circulating air flow system, much like the North Atlantic Current that moderates the temperatures of Europe. You can check this by taking a tissue paper and holding it up to the top of the doorway. The air flow should be pushing the tissue away from the room without the AC and toward the room with the AC. This happens because the warmest air will be toward the ceiling and you want that warm air to make its way across the ceilings and back to the room with the AC, so that it can be cooled again. The cooled air from the AC will sink to the floor and the fans will gently push the air out of the room with the AC. It will stay low and travel along the floor in the opposite direction and into the warmer rooms. If you crank your fans up, you will create turbulent flow and that will not cool your house as efficiently as will laminar flow. Monitor the outside temperature and when it gets cooler outside by a few degrees, turn the AC to fan for about 10 minutes to eek out the last of the cooling. Then open the windows for the night to take advantage of the free cooling that nature provides. That's it! Enjoy the summer!
on May 25, 2015 | Heating & Cooling
Placed in bedroom to heat large hall, office,dinning room, bathroom...making bedroom to hot
Placement of the heater is the problem. It needs to be in a more central location. Perhaps the hallway. That way, it heat has a more open area to travel and reach the areas you're trying to heat. Keep in mind though, it will always be hotter where the heater is located.
Be safe. Electric Space Heaters can start fires.
Mar 03, 2011 | Heating & Cooling
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
Airflow throughout House
The system you have installed what is the kw cooling capacity? do you only have one evaporator installed?
Jun 09, 2009 | Fujitsu 18RC Air Conditioner
Ac unit cools entire home except for one bedroom
The issue may not be confined to airflow alone. An air conditioner makes us more comfortable through two basic rules of physics.
It removes sensible heat (the temperature you feel) and removes moisture from the air. Dry air enhances the bodies own cooling system allowing perspiration to evaporate more quickly which speeds the removal of heat from the body, this is why 85 and dry feels more comfortable than 72 moist degrees.
to ensure the ducts are balanced properly one must use an anemometer which is a tool used to calculate airflow by the pro's. Being that most homeowners do not have access to one there are some good observations to make using a pocket thermometer and your own senses:
  1. Ensure the guest room vent is the same size as the master bedroom.
  2. Ensure the supply duct for the suspect vent is the same diameter and approximate distance from the main plenum (where the ducts originate) as the master bedroom.
  3. Is the air emminating from the suspect vent approximately the same in volume as the master bedroom (does it feel and sound the same).
  4. The issue exists even if the guest bedroom door is left open.
  5. The air temperature measured at the vents is within 3-5 degrees of each other.
If 1 - 4 are true check for #5, if # 5 is false make sure the suspect ducting is insulated or covered well by attic insulation.
If 1, 2, 3 or 4 are false: Ensure the following:
  • The guest room ducting does not have a damper hidden under insulation or duct wrap.
  • The duct has not been crushed or restricted.
NOTE: internaly insulated ducts can be restricted on the inside by fallen insulation while appearing normal on the outside.
If #5 is false (issue goes away if the door is left open) the door may need to be cut off a bit more at the bottom or a grill installed to allow the air coming into the room a place to go.
If none of the above reveal the culprit concider the room itelf, it may have a higher heat load than the others.
A higher heat load may be due to dislodged, compacted and or wet insulation in the walls or attic, feel the walls and ceilings with your hands, how does it compare with cooler rooms?
If the walls and ceiling feel about the same and the tests above did not expose an issue its time to call the contractor back in, make sure the static pressure is checked in each duct a foot or so downstream of the the plenum and again just upstream of the vent. A duct with air pressure higher or lower when compared with the others could mean a variety of issues with the duct or where it connects to the plenum.
May 26, 2009 | Heating & Cooling
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Our Masterbedroom (downstairs)does not get enough cooling or heating eventhough the a/c and heater are working fine to adjust temperature in the larger living room. The air blown through the duct is low in...
the air takes the path of least resistance.What you need is a balance.there should be some dampers in the round pipe of each heat run.restrict the ones going to the livingroom about half way....this will force more air to your bedroom.
Aug 06, 2008 | Heating & Cooling
AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Aug 01, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ruud Central System Air Conditioner Logo
152 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
