Question about Homelite Garden
On a homelite chainsaw model d3300 i have all fuel lines lose and have forgotten location of where they go. What is the locations of the supply lines from the gas tank to the carburator?
  • josh1111 May 11, 2010
    send me an email with a pic of your dilema, of the lines and were yo think they go .
  • 42 Answers
The line that hooks up at the front of the carb (#17 in picture) goes to the fuel tank. the line that hooks up at the rear of the carb (#18 in picture) goes to the primer bulb. Hope this all helps. Let me know. thanks.
On a homelite chainsaw model d3300 i have all fuel - convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chcp%5cimages%5c06%5c01%5c13%5c0007.tif&ilsc=12&iliv=0&ilbr=0&ilif=p&ilre=8
Posted on Mar 15, 2009
Where on the body of my homelite chain saw can I find the serial number! SuperXL 910 used to have a rubber insert?? +- 1971?
on the rear handle
https://www.jackssmallengines.com/jacks-parts-lookup/homelite-model-locator.aspx
and just for fun, this deciphers the date and other interesting stuff.
Figuring Out Homelite Serial Numbers - Chainsaw Collectors.se
www.chainsawcollectors.se/phpbb3/viewtopic.php?t=2543
Dec 28, 2006 - 15 posts - ‎10 authors
With this information, you can now de-cipher the serial number of your new old beastly beauty and find that she was made at assembly line ..
Jun 28, 2017 | Homelite Garden
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
My Homelite d3300 DX series runs great for a while then quits some say its a stopped up but it looks clean some say air filter it is clean do you have any solutions I mixed gas ratio 40:1
Hal:
Check the fuel filter at the end of the fuel line in the tank... sometimes it will get hung up in the tank and won't be immersed in the gas. also check to see if there is enough fuel line in the tank to ensure that the fuel filter stays immersed in the fuel in the tank.
Jan 02, 2013 | Garden
How do you clean out a stopped up muffler on Homelite d3300 chainsaw
Hal:
I remove the muffler, and clean it with a spray bottle filled with rubbing alcohol... make sure that the alcohol is completely evaporated before starting the saw with the muffler on it. You can also use carburetor cleaner. An old toothbrush comes in handy also.
I cannot locate my owners manual and have not used the Homelite Ranger 16 inch in quite some time --- What is the fuel and oil requirement??
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
Jan 19, 2011 | Homelite ZR10926 16 Chain Saw
I have a used Homelite d3300 UT10779 and no manual... need the gas oil ratio.
there normaly a 40-1 mix,,,i run mine in a 30-1 mix,, now i know your going to say "thats a bit ritch!" but my saw is 20 years old now? and i look at it this way,,,if you can see smoke you got oil?
if you run it on two stroke or engine oil you need to run it on the ritch side,,,so stick on 30-1
Nov 25, 2010 | Homelite Garden
Its sparking but not fireing for homelite 42 cc chainsaw. wat could it be ?
Try pouring a small amount of fuel mix into the spark lug hole and try for start. If it pops several times, then check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines and primer bulb. Does the primer bulb draw fuel into itself after several pumps? If still no help, go to: http://www.drystacked.com for a 12 page PDF article on Walbro brand carburetor theory and troubleshooting help. Pay particular attention to the location of the lower chamber gasket as shown in the article. Hope this helps!
Sep 05, 2010 | Homelite ZR10580 FactoryReconditioned 42cc...
I have a homelite chainsaw model d3300 every time I hold down the throtel it dies any idea why thanks Code dog
there are a number of things that can cause this. # 1, a dirty air cleaner element. # 2 the high speed jet needs to be adjusted out. # 3 a bad spark plug. # 4 a vacuum in the gas tank. # 5 the chain brake is on. Hope this gives you some clues.
Sep 10, 2009 | Homelite Garden
Garden Logo
788 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
