Question about Dell 924 All-in-One InkJet Printer
How do I load Paper???
How do I load paper??? Thank You.
  • 514 Answers
Go to page 19 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it). good luck!
Posted on Feb 28, 2009
Unable to close error message "Paper Jam"
unplug the printer, inspect it for paper jams, take the printer apart as far as possible and clear any paper jams in it.
for more specific instructions I will need to know the brand and model of your printer.
Thank,
Ekse
Jul 07, 2008 | Office Equipment & Supplies
It doesn't load paper,when paper was load in a tray,the paper was loaded in jam and also gone in bango.
Welcome to FixYa.
If the printer don't load paper, please follow the following steps.
1. Check the printer make sure no scraps of paper are stuck inside the printer.
2. To check remove the door at the back of the printer.
3. If you paper try to pulled the paper jam.
4. Double check again if there is scraps of paper.
5. Then put back the door of printer.
6. Then, Disconnect the USB cable from the printer.
7. Disconnect the USB cable from the computer.
8. Leave the cable unplugged for 5-6 seconds.
9. Reconnect the cable to the printer and computer. Ensure the printer is connected directly to the computer through a USB cable or power USB hub.
10. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Need a operators instruction manual so I can find out how to operate my printer,& fax machine Hewlett Packard Office Jet K80xi THANK YOU
I possess a digital copy of this manual. If you are interested, I can be reached at LBrown18062@hotmail.com. Please make sure to include the "HP K80xi" manual in your heading. Hope this works for you.
Contents
1 Review your unit's front panel. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
2 Use your HP OfficeJet with a PC. . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Review the Director . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Review the status window . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
3 Get help . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Where can I find help? . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
4 Load paper or transparency film, or load originals. . . . . . . . . . . . 7
Load the input tray with letter-, legal-, or A4-size paper . . . . . . . . . . . . . . . . . . . . . . . 7
Review tips for loading specific types of paper . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Load the input tray with envelopes (only works with printing) . . . . . . . . . . . . . . . . . . 10
Set the paper type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Load originals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Avoid paper jams . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Dec 27, 2010 | HP Office Equipment & Supplies
Got a Canon i850s used with no instructions. How do I load paper?
You have to open the front cover and move the paper thickness lever at the top of the print head holder to the left position, close the cover. Pull out the paper rest and the output tray and load the paper, aligning it with the right side of the sheet feeder. Press the paper guide and slide it against the left side of the stack of paper and you're done!
You can download the User Manual from the Canon website by clicking here
Thank you for using Fixya!
Nov 24, 2010 | Canon i850 InkJet Photo Printer
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
Wont load paper
http://h10032.www1.hp.com/ctg/Manual/c00739568.pdf
Download this manual above and go to page 13, It will show you how to load the paper and other things to consider.
this should do it for you, please leave a rating...
thank you kindly
May 10, 2009 | HP PhotoSmart 7150 InkJet Printer
Hi, Photo paper loads at start of print job but locks up and paper jamb error comes on. Have loaded 10 or 15 sheets of just photo paper that does not help. I can run standard paper thru and it prints pics...
Is this the first time you have used the heaver paper ? Also is it the same brand? You did not provide the printer model, but you can typically go to the manufacturers site, and check the specs for proper ( Mim / Max ) paper requirements. Above # 60 the paper feed rollers may have worn, and may need to be replaced. If 20 # copy paper works, then this may be the problem.
Nov 19, 2008 | HP Office Equipment & Supplies
Paper not loading (but it is)
If it's an older machine, try cleaning the Multi-sensor (next to the printhead with the scissors icon on it).
Mar 12, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson R300 printer
ok " if you look in where the paper is loaded on top there is a small switch with a finger , may be bent. tells printer when paper is low
rubber wheels that pull paper threw may be glazed , take sand paper and go over wheels to ruff up
Jan 22, 2008 | Epson (C31C411016) Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
