Question about Dryers
Dryer not heating up, but is turning
I have a Frigidaire Dryer model FERB6600ES0, and the dryer is not heating up. The motor is turning and working fine thou.
  • 54 Answers
You need to replace your heating element. You can purchase a new one online for approximately $55.
Posted on Feb 23, 2009
Not heating
This may require several trouble-shooting steps. First, it sounds as if the gas is turned on and ignited. It also, sounds as if the motor/blower is not rotating. Check the motor continuity, the electrical supply to the motor, and whether the motor (with electricity turned off) rotates by hand freely.
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
I have a Frigidaire Dryer Model#FEQ1442ES0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
My frigidaire dryer model GCEQ2152ES0 motor runs no heat. already replaced the contol panel when an error reading of E68 came up. Now I have no error reading but still no heat. I also noticed upon start...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Frigidaire GLEQ2170K Electric Dryer
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
My Dryer won't get hot
try doing the following checks--
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If you need the manual check the following link.choose the manual for the appropriate model.
http://www.retrevo.com/samples/Frigidaire-Dryer-manuals.html
Dec 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Dryer not going to full heat
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Nov 15, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
