Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
How complicated is it to replace the heating element in the whirlpool gu1500xtls1 Dishwasher? It is not drying. Can the element be replaced from inside the unit or does it does the whole dw have to be removed?
    President:
  • Whirlpool Master
  • 2,651 Answers
Would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Posted on Feb 23, 2009
Heating problem on dishwasher
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. To determine if the heating element is burned out, watch the part testing video at the bottom of this page.
Thanks
Apr 01, 2012 | Whirlpool ADP 8900 Dishwasher
Whirlpool dishwasher GU1500XTLS1 displays the number 2 and pumps out no other function works
Reset the machine. Press the control buttones in this sequence: sani-rinse,air-dry,sani-rinse,air-dary then clear! That should do it!
Nov 01, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
MY Whirlpool 6ADP 5550 dishwasher does not heat the water or heat to dry the dishes. the soap dispenser does not open.
the probable causes may be either the heating element is bad or its not getting the required voltage testing the heating element if you can or have the necessary tools like an ohm meter to check the heating elements for continuity and from the control board if its getting the required voltage(110/120V) .this test will confirm the problem .this can be best done by a qualified technician if you dont have the necessary tools.if confirmed then you can replace the heating element if bad. hope this helps
Jun 06, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Dishes won't dry. Is heating element the likely problem. Is it replaceable
What temp is your water? You may need to set your water heater up a notch. Try running the dishwasher on the "sani rinse" since this heats to 160 and see if they are drier. Is your heating element working? During the dry cycle with the heat dry on I would open the door and put my hand next to the element to see if it seemed hot. Maybe it isn't working. Also did you put Jet Dry in the dispenser?and also if the setting is adjustable you can dial it up a notch or two. I also like the Jet Dry Turbo. It makes my dishes dry completly, even plastics and this is on the no heat dry.
If there is no heat, then the heating element may be bad. You can get the part, and view diagram at partselect website.
May 18, 2010 | Whirlpool 24 in. DU920PW Built-In...
Not drying. is there a safe way to test the heating element?
Hello there
Here is a detailed list of things to check to ensure that the element is your problem cause there could be a couple of different things also click on the blue items
If the dry cycle has a problem, check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Best regards mike
Apr 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Not drying. heating element bad? easy to change?
Check the heating element to see if it is bad. If you just order a heating element for it, it will come with an element and a new control board. That should take care of your problem. Remember use only powder detergent in your machine. No tabs and no gel.
Apr 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
DU1055XPTQ0 DISHWASHER STUCK ON "CLEAN" BLINKS 7 TIMES, REPLACED HEATING ELEMENT ANYONE KNOW CODE TO RESET?
I believe its pressing heated dry, normal, heated dry, normal keys withing 6 seconds. There should be a tech sheet attached to the toe panel at the bottom front of the machine.
Feb 17, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Indesit DI620UK Dishwasher fault
Heating element
Drying fan
Thermostat
Jul 19, 2008 | Dishwashers
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
157 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
