Question about Nokia N73 Cellular Phone
Everytime i have to set the time & date
When i restart or change the sim card my phone, i have to set the date & time,before i have'nt this problem.
  • Anonymous May 18, 2009
    i had the same prob!!just format ur mem card and phone both and tthe time is automatically set!!
  • 4 Answers
Its because your battery is removed.......to keep the date and time intact there must
be some extra charge to keep it going like CMOS battery in computer...
If your battery is removed then the clock will be reset....
Posted on Feb 23, 2009
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
I have a problm that my iphone do nt shwing sim card
it looks like sim card try is having issue. just change sim card try and it should fix the problem. but if still dont work then you broke on of the pin on sim card holder. check that
Feb 11, 2013 | Apple iPhone 3G
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Nokia n80 is offline and does'nt read simcard
Try this:
  1. In offline mode *#7370#
  2. Restart
  3. Enter city/time/date etc.
  4. Plug phone into charger
  5. Change network to automatic
  6. Activate pager profile
  7. Turn off phone
  8. Turn on phone
  9. Change profile to general
Jun 28, 2011 | Nokia N80 Cellular Phone
3 digit combination
I use a sidekick Lx for At&t that I unlocked myself. When you start up your sidekick it should ask you for a network unlock or ask you to enable your sim card just click the cancel key on the top right of your device. Now click the top left menu button and go into your settings, and go to 'sim center' it'll ask you to enable your sim card again just enter a random 4 digit number and it'll tell you its wrong but thats ok, click ok and just cancel it out :) it'll then show you "disable sim lock" "change sim pin" change your sim pin to a number you'll remember because the way im showing you you'll have to do this every time you restart your phone (my sim pin was by default 1111) you can enter the same pin number for the old sim pin, and new sim pin options. Once you do that a white phone icon should appear on your screen underneath your time and date. Now, go back into your settings and go to network options, scan and select your network manually, and there you go :) Sorry though with all unlocked phones you'll only be able to make calls and text. No picture messaging sadly :( You need a T-mobile sidekick plan for all that :(
Sep 15, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Time and date reset
yeah it is mandatory that you should enter date and time everytime you restart you mobile..thank you!!..
Jul 08, 2008 | Nokia 5200 Cellular Phone
Please help me....
remove ur memory card
then restart youre mobile
Jul 01, 2008 | Nokia N72 Cellular Phone
Master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#7780# Restores Factory Settings (Memory, language, counters are not included).
Press the following warranty code :
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
3: Press the "C" key.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Jun 10, 2008 | Nokia 3110 Cellular Phone
Nokia N73 Cellular Phone Logo
145 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
