Question about Quasar Heating & Cooling
What is the BTU's of Air Condition Model #HQ2201 GH. 230V 208F
    Scholar:
  • 144 Answers
It would be between 19,000 and 21,000 BTU's
I hope this helps. Please don't forget to give me a Fixya rating
Posted on Feb 23, 2009
Unit runs well but won't turn off when tepm setting is reached
In the Remote SET the AC FAN IN AUTO MODE THE AC stops after attains the set temp.
Apr 26, 2016 | Kenmore 18,500 BTU Heat/Cool 230V Room Air...
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
230V FEDDERS I HAVE 110V AND 20AMPS COMBINE HOW MANY AMPS DOES 230V NEEDS
I give simple formula to determine amps:
I (amps or current) =watts/volts.
And with above formula,you can calculate volts and watts too.
Helpful?
Jan 05, 2011 | Friedrich X-Star XQ10L10 20" Air...
Size of air condition.
Get the cubic volume of the room. The highest temprature differential. and how many air changes you need. this will give you the btu required.
If this is too high, get the biggest unit that your supply can safely carry.
Mar 27, 2010 | Samsung AW1091L 10,800 BTU Air Conditioner...
How to connect 230V,60Hz 2400 BTU Airconditioner in 115V 60 Hz environment. Mainy how do you get a 230V supply requirement.
Impossible to do because the compressor is wired to use 230V. The motor on the compressor won't even run. You will need to have an electrician come in and check your breaker box to see if you can add a 2 pole breaker that will be needed to run the a/c. To add 230 volt, you will need to upgrade the wiring as well as the breaker. I wouldn't recommend you doing this at all! You risk killing yourself and or burning your house down. Hire a proffesional for this job.
Mar 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Replaced window unit - new one won't power up (2nd model)
green light comes on when reset, when try to test goes out, power does not come on at all
Aug 09, 2007 | Samsung AW0503B Air Conditioner
Heating & Cooling Logo
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
